Results 1 to 16 of 16
    Mar 2015
    New York
    Default 6'1" and not a cluie
    I have seen a lot of threads on windshields but so far the answer is escaping me. I am 6'1"m and I am looking to get the '15 RT limited with the heated comfort seat, which puts the riding position back 2". I definitely want to go with a vented shield but I am not sure where the 23" or 25" shield falls as far as seeing over or seeing through for my height. Can anyone close to my height share their thoughts? Sorry if this has been covered elsewhere but I have been all over this joint and haven't found a close enough answer. And yes, I realize that i am being very specific. lol
    Jun 2010
    Las Vegas
    Hi, are you planning on getting the BRP vented windshield? I had one and thought it was a waste of money. The stock shield on the 14 & 15 has holes that do a pretty good job of letting some air through. The BRP vented one only allows you to open or close the vent and you can not aim the air flow. I'm 5'10" with long legs and I have the Comfort Seat. I ride with my shield down near the lowest setting as I prefer to look over it rather than through it.
    Not much help, sorry.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Feb 2009
    Canby, OR
    All of the windshields worth the money are aftermarket windshields. Use the stock windshield as your assessment tool - it will either be a 23" or 25", and most likely the 25".
    If it's too tall, get a shorter one, if it's too short (like mine was) Look at the F4 +3", which won't be.
    I'm 6'4", & my wife is 5'11"
    Mar 2015
    New York
    Thank you so much! Actually, both your answers help tremendously. I guess I should just get it first and see how it feels before changing everything! I have new toy-itis! Lol Thanks so much!
    Active Member bayoumanPIBE's Avatar
    Columbia, MO USA
    I'm 6'3" 276lbs inseam 33". I just installed my new calsci XL and it has been well thus far for me. The extra 6" helped me.
    Life's short...Play it by ear and ryde!
    Don't forget; you've got a decent adjustability range for the height of the screen.
    Get the one that you can comfortably see over at the lowest setting, and still be able to raise it up enough to look through it, should the need arise.
    Happy hunting!
    Sep 2013
    Houston
    Quote Originally Posted by Midian View Post
    I am also 6' - 1" and ride with an Ultimate Tall Boy seat, about 1.5" back from stock. We have been very pleased with the stock 25" vented windshield that came on the RT. I look over it in the down position and through it in the up position. I think you should do some riding on your new RT before you decide. You may be very happy with stock in this case. Are you SURE you want the BRP Comfort seat? They are much harder than the stock seat, I consider my purchase of one as wasted money. The Ultimate works much better for me but some find them too wide at the thighs. Each is different, you need to sit on a few before deciding.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jun 2013
    6'2" and have the stock windshield on my 2013 RT LTD . . . I look over the top. With the windshield lowered all the way, the wind just hits the top of my helmet . . . I'm quite happy with the results.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    I am 6 foot 1 ish, and I leave the Fat White Chick's windshield up all the time. I get too much buffeting if it is any lower, and I don't have any problems looking through it.
    People led talk about needing to see over a windshield. If you can see over it, whatever is coming at you, including stones and large bugs, can reach your head and face.
    May 2013
    Stanton, ca
    I am 6' 4" and got the 25" vented windshield on my 2011 RTS.
    As Ann said you wont feel any air but that is not the point for me. What the vented shield did was reduce the back pressure on the windshield when all the way up. This reduced significantly the forward and back buffeting in wind (lurching if you will). Prior to getting the vented windshield I ran the stock un-vented down all the time due to the buffeting.
    At 6'4" when it is all the way up. I am looking through the top edge a little. Does not bother me.
    For me the vented shield was worth it.
    Bob
    Nov 2012
    North Las Vegas, NV
    You should ride your Spyder for a while to see what does and doesn't work for you. Get the seat to your liking first, then change the windshield. Some seats have you sitting higher or lower,forward or back and may change your relationship to the windshield. Good Luck on your choice.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2013
    Oro Valley Arizona
    I have the vented W/S and as Ann says it is a waste of money. It is very narrow and wind will be beating your shoulders. Vents open or closed makes little difference for ventilation. Vent closed causes a lot of burbaling on the top of your helmet.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Feb 2009
    Canby, OR
    The vented F4 is much wider than the BRP version. I dumped my vented BRP for the F4, and am very happy with the change. I have no idea why BRP narrowed the vented touring windshield, but they did.
    Jun 2014
    Yorktown, VA
    I am 6'2"...with an inseam of only 29"...needless to say I am all torso.
    Just have gotten to ride my new 14 RT Limited this weekend for the first time I getting my head bounced severely! Would the F4 vented be a good option for me?
    May 2013
    Indiana
    Default Riding In the Rain
    How do you keep from getting soaked with a Cal-Sci XL since the vent is always open???????????
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    Default Cal-Sci
    Cal Sci
    It's magic!
    I have a Calsi Tinted shorty love it.
    When it rains it doesn't come pouring through the Hole!
    It's Magic.
