Keep 3 Down..!!!
Finally, picked up my bike Friday and rode 300miles home with a Chase trailing. The magneto had to be cut from the bike in order to install the new one. Other than a dirty bike, sticking controls ( turn, cruise ), it was a relief+very enjoyable ride home.
Keep 3 Down..!!!
Same thing for me
Glad to see that the stator fixed your problem, I had the same thing happen, while riding I did sense some electrical smell but it diminished and thought nothing more than it was something from a passing vehicle. I then had the battery light flash on and off for a few KMs and the then it started with a VSS code, them ABS codes and all kind of lights. I went and bought a new battery, activated it and charged it overnight and tested the charging system to find no charging at over 4000 RPM. sad to say it but further investigation and my meter found the Stator shorted to ground. Pins 1,2.3 and lead to ground should be OL bit mine had readings of 8.3 ohms. I now have to wait for my Dealer to take it and diagnose it. I will let you know how it turns out. 2 year old battery was swapped out and maybe the cause but I doubt it as the 60A fuse it didn't blow so it is fine. I have a another possible crispy stator. TBC.
Originally Posted by Spyder in La.
Thanks, I'll contact them tomorrow .
I have the same problem
Dropped off the bike at the dealer. The new battery did not resolve the problem.
I have put several LED lights and wonder if the stator is not giving enough voltage back to keep the battery charged all the way.
Left the bike at riva Motorsports in south Miami. They tell me the parts should be in by Tuesday next week.
My service contract should cover all expenses.
The battery is new but the system is not generating the needed voltage to keep it going.
I haven't experienced any problems since the repair of my stator.
Keep 3 Down..!!!
I talked to the dealer today and the parts should arrive Tuesday next week. I hope that it takes care of the problem.
Luckily the extended service contract covers all costs. Great investment
