Search feature is useless
I had the stuck gas cap problem and tried search using "gas cap", "cap", "stuck gas cap". Nothing got me any results. So I googles "stuck gas cap Spyder" and got dozens of results, mostly on Spyderlovers.
Bing!
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
Also tried each word separately. Same results. Doesn't matter. There's always Google!
So demand the money you pay to belong to Spyderlovers be refunded . . .
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
I find the same thing, use Google or ask. Com and it take you to Spyder Lovers.
Ryde as if your life depends on it,
because it does !! Ryde Safe!
Vietnam 67-69
VBulletin (which is what this site uses) is just that way. It's one thing they just have not done a good job of implementing.
I run several Vbulletin Web Sites and this is a number one complaint.
Bob
2011 RT-S SM5 - Black
Use " marks
One trick. If your searching on more than one word and put "s around them then you will only get results that match all three words in that order:
e.g.
"stuck gas cap" - comes back with just three results
"gas cap stuck" - comes back with just one
stuck gas cap - comes back with 20 pages worth - most of which will be junk. Basically any mention of stuck, gas or cap.
You'll probably still need to play around a bit with the words you choose but it really helps cut down the rubbish.
Use Google Site search
Google has a method of just searching a specific site.
In Google try site:www.spyderlovers.com "stuck gas cap"
As mentioned above enter your search string inside quotes although even without them Google is more intuitive.
Note: Looks like the forum software added a hyperlink to the www above. Just enter the whole phrase in Google search.
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
