Results 1 to 7 of 7
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    Default Help info 14 RS-S bar risers
    Are there any handle bar risers for 2014 RS-S?
    Thanks in advance from Advance.
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    Default Not sure..!!
    but check with the vendors on the home page. Some have them and should fit. Check also the for sale forum, think I've seen some for sale there...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2015
    Advance, NC
    Jun 2012
    Carmel, NY
    Default 2014 RS-S risers
    Did you ever find anything? Need them for my 2014 RS-S; thinking of putting Tri-Axis bars.
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default nothing yet
    the way the bars are styled, it seems like it would be pretty tough to come up with a riser that would look good. st or rt bars on the rs look the best. the bike still looks stock. if the easyrisers can be put on, there would be many others too. dogbones, snowmobile risers, easyrisers, ect. any that will fit 7/8 bars, but what's that going to look like? If you want to do it anyway, I think there's a thread in Diy on it.
    it was fun while it lasted.
    Jun 2012
    Carmel, NY
    Default 2014 RS-S Risers - Success!
    I was able to have dealer successfully install Tri-Axis Bars on my 2014 RS-S, even though BRP didn't recommend it as its not made for that model.
    Another option, would be the bars off of an ST.
