Try this instead: <a href="http://www.spyderlovers.com/forums/showthread.php?108712-205-60-15-on-rear-of-RT&amp;highlight=rear+tire" target="_blank">http://www.spyderlovers.com/forums/showthread.php?108712-205-60-15-on-rear-of-RT&amp;highlight=rear+tire</a>.
There are multiplicities of other ones out there. Rather then the DIY forum search in the maintenance forums. I just went to my local tire store and asked him for his best tire in the correct size,gave him the wheel and he mounted the tire.
Thank You. I've been doing quite a bit of searching since I need to replace this tire before I can get the bike inspected and you can nuts trying to figure out which one to go with. I've found that it is better to do a straight google search and then look back in these threads then it is to try and use the search function at the top of the page. The results are generally more meaningful.
Unfortunately, it seems like some folks would rather be rude and condescending rather than helpful. I'm sure tires as well as many other topics have been beaten to death in the past, but it takes about the same number of keystrokes to be considerate and point new folks in the right direction as to just shut them down.
