cat delete or not
well thinking of different exhaust on my 13 rs but can,t seem to decide.
should I take off the cat and see what that sounds like and maybe a different
muffler too. or just a muffler. the sound clips on you tube do not sound
all that realistic to me. not looking for more power just a GOOD sound and
not to loud. and I don,t want to get into a fuel issue. so with that
being said what are they doing out there to get this.
benefits of changing the cat are they worth it or not.
what exhaust seems to have the tone.
cat delete or not
I pulled that boat anchor of a secondary muffler (cat) off replaced with pit bulls pipe and love the new sound with stock F3 muffler
Another Day To Be My Kid's Dad [emoji379]
2015 F3-S. And Another Day To Be My Kids Dad
Sounds....
Not looking for performance I would eliminate the cat a lot of heat and weight. The change in sound is nice and may be enough. If not then the Yoshimura R77 is a nice pipe with a baffle you can add to tone it down...
2012 RS sm5
is spyder attitude the only place to get the bypass, there price seems out of this world for that.
I know there is a little work put into it but come on man.
and not even a dinner out of it
ok this may be a dumb question but what exactly are the benefits of removing the cat
Reduction of heat under the fuel tank (boiling gas).
I bet if you take off your catalytic converter off ... bring it to a muffler shop.. they could make just a pipe to replace the cat... for a lot less...
osm
That is the way I am headed also
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
Do some homework.
Some states probably have laws requiring the cat converter. It would do you well to check and be sure you won't get gross wise with the law.
Just say'n.
So far, my second childhood is better than my first.
osm
That is a good idea Orange Spyder Man. It never dawned on me to do this. I was going to buy one from Lamont/Len this spring, but with our Canadian dollar being so low. I think I may just try this avenue. Never hurts to try. I have a guy down the street from me that does this.
Although it won't give the "real life/in person" quality. Would you mind throwing up a short video? I'm interested in hearing the difference and don't recall a stock setup minus the cat being posted.
Current Spyder
2015 Magnesium Metallic F3-S SE6
- Gauge Spoiler - Pegs @ #5 - Long Reach Bars - Detachable Passenger Backrest - Cross Country Saddlebags - Power Commander V - Power Commander Auto-Tune - Power Commander POD-300 - Two Bros S1R Exhaust w/Black P1X tip - Two Up Shock - Detachable Driver Backrest - Spyclops LED - LED Headlights - Route 129 Windshield
Retired Spyder
2013 Magnesium Metallic ST-S SE5 5,467 Miles
Ryding Since 1/19/13
i took the cat out on my 14 rt just because,,, if you do it, wrap the bypass pipe b4 you install it, it reduces the heat even more
NO BIKE AT THIS TIME
No, you can get it from Lamonster garage or Pitbull Powersports in Springfield Mo.
Cruzr joe
Nobody mention the benefits yet if you remove the cat. Anybody know?
2012 Spyder RT SE5 Brake pedal mod
See post #6
Good job, it's not a race to get it done, so congrats. I'm sure you will love it once you can get out on it.
cat delete or not
I did notice that only one pipe had a retaining spring also noted that some one else here had the same issue, sent BRP an email to ask them whats up will update
When the bloody weather settles and the snow goes away so that I can move my Spyder from the back yard patio to the garage, I'll replace the stock muffler with the Yoshimura R77 that is in a box on the garage floor and install the K&N air filter that is on a shelf in the garage. Would y'all recommend that I disconnect the battery negative while I'm doing the mods so that the computer can update itself straightaway after I push the starter button?
Well now, I got no response to my question from anybody, so I installed the Yosh pipe then started the motor and let it idle for about 15 minutes, then shut it off. waited about 15 minutes, then started it again. Idle is smooth, response is instant. I think it'll be OK. Oil change coming up soon, so the air filter gets changed then.
Also installed a KAOKO throttle lock. Operation is similat ot a throttlemeister, but seems to be easier to operate. I give an update after I've used it for a bit.
Thanks for the info
cruzr Joe
Cruzr joe
I wish either of these fine folks would actually put the cat bypass on their web sites! I admit I hate talking on the phone (and its tough with my work schedule)
Pop on their web site, order, pay, done. Wait for it to show up on my porch!
- Duffer
Camano Island, Wa
2013 RTS SE5
I will say yup to that
