Help!! Clutch lever has no Tension?
hi all, start my spyder up today, and clutch lever has no tension at all!! I'm so afraid to put it in to gear so i didn't. any though before i call my dealer. Thanks.
its a 2013 ST-S SM5 with about 550 miles on it, not even first oil change yet...
Check the fluid in the reservoir. Could be low or needs to be bled.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Agree..!!
You may have to bleed the system. If it is low on fluid you need to see why. Seems to have very low mileage to have lost pressure. Check for leaks at all points. If there are none it could be in the slave cylinder. Hope you find the probkem else take it to the dealer...
thanks,
yeb, the reservoir is empty, there are no leak spot on the floor! i'll let you guys know how its go.
My GS did this it puddled on the plastic. It was a o ring in the slave cylinder. $3 fix.
I had an RT that did the same thing. Nothing on the garage floor it was all on the plastic.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
had the same problem
When my spyder was new had the same problem slave end was leaking internally dealer needed to rebuild. Guess there must of been some defective 2013 sts units
Thanks, will call the dealer for appointment when all the freaking snow are gone...
Do it now while the snow is here and ride when the snow is gone.
Cruzr Joe
