Hard time deciding!
Hi all,
I'm in the market for a Spyder and am really torn between the ST and the RT. Apples to oranges, I know. I had a 2010 RS, and ended up selling it to go back to 2 wheels. Now I find that arthritis and my knees have become super good friends, and 2 wheels just won't work for me any longer. So I went looking today to check out the ST & RT and a having a hard time making a choice. I ride with a group, but mostly do day rides, with the occasional long distance ride thrown in. I plan on keeping this ride for a long time, but wonder what everyone rides and if an ST is better for a daily ride vs the RT? Thanks for any advice you all can give to help me with this decision!
Reason: Forgot the rest of the post!
Given I have the same issue - if you are tall, the RT with floorboards would be the ticket. Under 6', either the F3 or ST are worthy contenders.
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
Originally Posted by akspyderman
If you want to move up to the 1330 triple, the RT is the only way to go.
I do recommend a test on that platform to see if you like it or not.
Some "Saddle Time" may help you settle this out.
Happy Hunting, and Good Luck!
You really should try them both out. You'll probably like the 1330 engine.
Depends..!
On what you were ryding and how your new found friends are affecting your ryding. You do have a third option which is the F3. The test ryde will be your best bet seeing as most folk love what they have or they wouldn't have it.. a lot of advantages going with the triple ( 1330 ace engine in the RT and F3). Love my RS with the V-twin. Good luck...
2012 RS sm5
Hard Time Deciding
Please be informed about the maintenance of the 1330 vs the 998. From a maintenance point of view the 1330 is better, easier to do (with the F3) and the interval between oil change is longer. 998 twin uses oil, the 1330 doesn't. Just some considerations.
I sat on an F3 for about 3 minutes the other day, and just had breakfast this morning with the local Spyder group, one of whom brought his brand new F3 which several of us admired. I've ridden my 2013 RT for 13,000 miles. My recommendation is, if want the sporty ride and feel, and somewhat of a "hot rod" buy the F3. If you're into leisurely touring with overnight baggage along, then go for the 2014 or 15 RT.
If money is a significant consideration then look for a used one. If you come across a 2013 RT do your best to make sure it hasn't been a seriously problematic one. In spite of what you read here about all the bashing of the 2013 RTs they are not all super hot boxes waiting to burn up.
2014 Copper RTS
Gimpy Gimpy Gimpy my NJ friend.I got a 2014 RT-S in November.You would love the RT and be very happy with it
2014 RT-S SE6 Pearl White
Grip Puppies, 12 volt power outlet, BRP comfort seat, Tri-Axis adjustable handlebars, BajaRons sway bar & links, Spyderpops Bump Skid w/Inlaid LED's & Stainless steel Kott grilles,SmoothSpyder belt tensioner,Carbon fiber dipped wind deflectors,Lamonster NBV highway brackets,Lamonster cat delete pipe,
F3
Thanks everyone! I sat on the F3, but it's just not my style. As soon as the snow clears, I'll test ride both to see what fits best. Thanks to all for the advice! Trooper, will be on the lookout for you and your new ride this summer!
Where are you in Northern Jersey?
(I fought the "Battle of Route 206", while serving my collegiate sentence in Lawrenceville...)
Perhaps a ride can be arranged this Spring.
And there's always the Chatterbox on Thursday nights...
Nobody is going to be able to answer that question. You are going to have to sit on, and ride each and figure out what works best for you. There are subtle as well as pretty significant differences between all the models. Good and bad.
Good luck with your search!
I have a 2014 ST-L and don't have any gas or oil smells nor any heat issues. I love my Spyder soooo much, it has plenty of git up and go....I have no issues going 85 if I need too. I have no worries about going for a week long trip, plenty of storage and comfort for me. The ST is a more sporty model and I do believe that your knees are in a more bent position than on the RT so that may be a consideration for you. The RT is a bigger bike...more storage and bigger engine. It is more of a touring ryde but obviously would work beautifully for a day ryde. Another thing that may make a difference for you is getting on and off. The ST and RT are both set up a little different and it may be easier on one than the other. As in the previous posts I hope you have a chance to test ryde and play with both.
2016 F3-L Special Series Triple Black
August 25, 2016
2014 ST-Limited
July 2, 2014
"Just going down that long lonesome highway" and now REALLY loving every minute!!
Get the 1330... If you want more of the hot rod feeling go with the F3. If you want more storage and touring comforts (stereo, wind protection, etc.) get the RT. And, if your wallet allows, get the RT Limited
2014 Spyder RT Limited SE6
BRP Tri Axis Adjustable Handlebars
BRP Adjustable Wind Deflectors
BRP RT Passenger Armrest
BRP Driver's Backrest
BRP Travel Cover
Baja Ron Swaybar
SpyderPops KOTTS
SpyderPops Bump Skid
Lamonster NVB Highway Brackets w/ Gripper Pegs
Lamonster LED Headlights & Fog Lights
Custom Dynamics HMT Brake Light
Show Chrome 7.5 inch Spiral Antenna
SpyderFlap Mud Guard
Helmetlok w/ T-Bar Extension
Hopnel 5PC Luggage Set
Airhawk R Seat Cushion
Rivco Dual Flag Mount
Apple, I live in the Wayne area. Not too far from 206. Storm Trooper is a few towns away from me as well, so a ride could shape up!
That makes three of us in or near Wayne
Sent from my Nexus 4 using Tapatalk
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
