Results 1 to 25 of 25
Thread: Sway Bar
    Active Member Gator37's Avatar
    Jun 2013
    Soap Lake, WA
    Default Sway Bar
    I have ordered and received my Spyderpop Bumpskid and s friend suggested I also add a sway bar to my new '14 RT-S. Is that something can be done after the bumpskid is installed or does it need to be installed before the Bumpskid. Am not wanting to have to remove the bumpskid just after installing it. Thanks,
    Ken
    American by Birth, Southern by the Grace of GOD.
    The Older I get the Better I Was.
    Bryant, Arkansas
    Quote Originally Posted by Gator37 View Post
    Ken
    On the 2014 the sway bar is back further than the bumpskid (just crawled under it to check) so no need to worry. Be sure to order the helm links when you order the sway bar or you will be doing the sway bar twice.
    Cruzr Joe
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Joe, Ron ships the links with the bar now.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Bryant, Arkansas
    Quote Originally Posted by bruiser View Post
    Great, I was not aware of that.
    Thanks
    Cruzr Joe
    Default Relax..!!
    you can do the bar whenever your ready. If you have no issues with handling you can wait on it but it is an impressive change once installed if you like winding roads.
    ​2012 RS sm5
    Very Active Member bullant12's Avatar
    Oct 2010
    Somewhere out there...
    Also, you can exchange the heim links without having to remove the sway bar or lift the Spyder.
    May all your encounters with the law begin with the words: "nice trike!".[/B]
    2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
    Previously owned:
    2010 Can-Am Spyder RT SM-5
    2011 Can-Am Spyder RS-S SM-5
    2013 Can-Am Spyder RT-S SM-5
    Very Active Member latony007's Avatar
    Jan 2015
    Outside L.A.
    im really considering this on my 2008 RS. everyone seems to rave about it. It amazes me that a bar of metal could make the bike handle that much better, or i guess what amazes me is that if it does make it handle that much better why its not on there from the factory, even in newer models. I have no way to lift it or very much mechanical skill and my dealer wants 145 to replace it.
    Tony From Los Angeles
    Current
    2015 Spyder RT
    2012 Yamaha FZ6R
    Previous
    2008 Premier GS #588
    2005 Suzuki C50
    2007 Susuki S40
    BRP tuned the front suspensions for a very soft and compliant ride...
    It was simply a marketing choice that they made.
    I WILL say that I love the feel of my 2014 in the turns.
    It's about 90% as responsive as my "Elka and RonBar" equipped 2010 RT, with a much more compliant ride...
    GreatFalls Montana
    Default sway bar
    I didn't get the skid plate, but I did have the sway bar installed. The swaybar makes a big difference in the handling especially in corners.
    2014 RT L Lightin' LeeRoy
    1980 CM 400A
    1982 CM 450A
    [/SIGPIC]Lightnin' LeeRoy
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    I installed a bump-skid then installed BaJaRon sway bar... you don't have to remove the bump-skid..
    osm
    Jun 2013
    Soap Lake, WA
    Default Ordered Bajaron Bar
    OK, I ordered a Bajaron Swaybar this morning and talked to a really nice guy there. He was very informative and helpful. And yes, with he 2014 bars the other needed pieces are included.
    Ken
    Jan 2015
    Outside L.A.
    Ken
    We need a group buy on these
    Make sure you run a good twisty before you put it on and then run the same road after and give me your opinions. Im very close to pulling the trigger on one
    thanks
    Current
    2015 Spyder RT
    2012 Yamaha FZ6R
    Previous
    2005 Suzuki C50
    2007 Susuki S40
    Go ahead; pull the trigger!!
    You'll be amazed at the difference!
    Jul 2014
    Nowhere
    After riding SWMBO's RT for a while, I thought the ride was pretty good, but then I road yesterday, on the freeway, with the screen in the highest position. It was twitching all over the place. Never to the point that I was uncomfortable, I just had to be at attention with the wind and the trucks. I believe that I will made a suggestion then buy her an early anniversary gift.
    Active Member NorCalBud's Avatar
    Feb 2013
    Northern California
    Default Just Do it!
    Quote Originally Posted by latony007 View Post
    thanks
    Both my wife and I (ryding Double) could literally feel the difference just turning out of our driveway onto the street. She always felt like our '12 RT would be out of shape in the curves and I would feel it diving....But not since I got that bar! The Trike now takes those twisties like a pro and the wife is happy-happy and no longer nervous in the curves. 'nuf said...
    ~'12 RT Limited, Pearl White~
    BajaRon Anti-sway Bar
    Squared Away Laser Alignment
    Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
    Lidlox Grip Tip Helmet Locks
    TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
    Palmer Signs Custom "Captain America" frunk graphics
    Twisted Chrome Pinstripes
    Overland Australian Sheepskin Seat Cover
    Jan 2015
    southern WI
    Based on all the posts in different threads, I'm about ready to order the BajaRon bar as well, before even riding my 2010 RT. How high does it really need to be lifted to do the swap? Will standard car ramps/jack stands get it high enough? I'm mechanically inclined and good with taking things apart, and I have some pretty decent tools as well. But I don't have other means of getting the front end in the air.
    2016 RTS , Pearl White
    With a set of car ramps; you'll do just fine...
    You basically need to get just high enough so that you can sneak down underneath the nose of the bike on your back...
    Nov 2012
    North Las Vegas, NV
    Did my 2012 on car ramps with no trouble.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2015
    Outside L.A.
    Alright i think i am convinced, where is the cheapest option for buying one of these? All the bars now include the links i have been reading about? Im going to have to have it installed i dont have ramps or lifts or really anything but an average tool box lol.
    Current
    2015 Spyder RT
    2012 Yamaha FZ6R
    Previous
    2005 Suzuki C50
    2007 Susuki S40
    Very Active Member one2doo's Avatar
    Oct 2007
    Johnson City TN
    I'm waiting for someone to try one on a F3 to see if needed. I know BAM has a rt one but needs to thaw out so he can ride.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by one2doo View Post
    Results coming soon to a post near you....
    Oct 2007
    Johnson City TN
    Thanks Ron I knew you would be on top of it.
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Tony,
    I used Arntufun's videos to remove my frunk, panels & install my BajaRon swaybar on my '08.
    Here it is: http://www.spyderlovers.com/forums/s...ay-Bar-install
    I have been wrenching on motor vehicles since 1954 so this was rather easy for me. But I did follow his instructions to the proverbial T.
    Randy's videos are the best that I have ever seen. And that is not meant to be negative to anyone else who has posted videos; they all help.
    Go for it guys,
    Jerry Baumchen
    PS) I just spent a 'few' hours removing my Sport Rack, installing a Corbin seat & reinstalling the Sport Rack. I had two printed sets of instructions and one video to refer to. They helped a lot; BUT none of them mentioned those two little 6 mm allen drive screws that have to come off of the bottom cover of the Sport Rack.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Invalid Emails
    Oct 2014
    Calgary, Canada
    Now that is a valuable comment... thank you.
    Very Active Member GunDoctor's Avatar
    Sep 2014
    Los Angeles
    No need on the F3 in my opinion. The bike is amazing.
    Another Day To Be My Kid's Dad [emoji379]
    2015 F3-S. And Another Day To Be My Kids Dad
