"Limp Home"
While ridding last week my Spyder ST Limited went it the Limp Home mode.
What would cause this?
Three weeks old.
Thanks
Bummer..!!
sadly many things. You would need more information to diagnose. What lights on the dash came on..what message scrolled across the screen..what codes were given etc. There is an app for this. Download to your phone or computer. My spyder for apple and spyder codes for android. As a new ryder things like ryding with your foot on the brake can cause this. Try the "key walk" remove the key and walk away for a few minutes then restart. If all is well then the code, if any, is stored and at service the buds system can tell you but you will be good to go..check all fluids to be sure...
2012 RS sm5
did you make a sharp turn, were you riding the brake, did you over rev, there are so many things that can cause it
NO BIKE AT THIS TIME
try turning it off and removing the key, walk away with the key at least 20 feet for at least 5 minutes. When you come back to it and it starts then you need to look at some of the suggestions above such as don't ride with your foot resting on the brake. Don't wash your Spyder with a hose and get all the electricals wet, be sure your battery connections are tight. Be sure to come back and let us know if this works.
Cruzr joe
If you will retrieve the codes, folks here can tell you what is going on and what if anything needs to be done.
Limp Home Mode
The dealer is picking it up today.
Thanks to all above.
I'll let you know the results.
Rode Harley's the last 30 years.
Enjoying the heck out of the Can-Am.
Hope it's a quick repair.
Don't get discouraged, best of luck.
limped home
The dealer picked the Spyder up yesterday. Tech started it. Computer showed , running hot.
Hope to know something later today.
Granbury Motorsports
"Thank You"
The limp home mode came on on mine two days ago for the first time in three years. All I did was ran over the rumble strip on the side of the highway while pulling off to the shoulder of the highway. The DPS came up and went into limp mode. I shut the engine off, waited 30 sec. ,restarted and all was good. Checked codes and nothing indicated so all is well.
Roger
2012 RT Limited
Vertika Floor boards
Painted rear fender & dash
Carbon fiber panels
Utopia back rest
Baker air wings
Elka shocks and relocaters
CB radio
ISO hand grips
Tric LED fender light
Turn signal lights in mirrors
Roger
Loose wire. Point it out to your dealer next time it is in.
2018 F3 LIMITED
Limp Home
Fan motor needed to be replaced. Take about a week to replace the fan motor. No problem.
This week forecast. Rain, sleet low 30's.
Im a 60 or above rider.
Glad they got you figured out.
Cruzr Joe
