Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
  1. #26
    Jul 2016
    Default THANKS FOR THE VIDEO
    JUST REPLACED MY BATTERY IN MY 2012 RT. WENT TO THE DEALER AND HE WANTED $155 FOR THE BATTERY AND $150 LABOR. DECIDED TO TRY THIS MYSELF. TOOK LESS THAN AN HOUR. WENT TO ORIELLY AND GOT A SUPER START, ETX 18L FOR $110 AND A $25 GIFT CARD, SO SAVED 150 ON LABOR AND $65 ON A BATTERY, THANKS
  2. #27
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Quote Originally Posted by meatman View Post
    Bob
    2011 RT-S SM5 - Black
  3. #28
    Active Member cmar157's Avatar
    May 2012
    Sanford, Florida
    Default Found at Amazon
    Looks like Amazon has them a little cheaper, just want to verify this is the right battery for a 2012 RT
    https://www.amazon.com/Yuasa-YUAM725...=YTX24HL+yuasa
    NEW 2016 RT-S Special Series Triple Black - ready for new toys to add
    OLD 2012 RT-S Pure Magnesium Metalic CB-Navigation-XM, Sway bar, Ultimate Tallboy
  4. #29
    Jan 2008
    California
    Default Second replacement
    Bob,
    I just reviewed your video for the second time. I replaced the battery in wife's 2011 RT after watching your vid. I looked up again just now and re-found your vid. Refreshed my memory. I haven't purchased a replacement yet, but will remove and first choice is Battery Plus. I have had good luck with them and Goldwing batteries. After I'm finished, I'll post my efforts. Thanks again for your video Bob.
    Joe in Modesto
  5. #30
    May 2013
    Stanton, ca
    Quote Originally Posted by jomamma1 View Post
    Bob,
    Joe in Modesto
    Your welcome Joe... Glad I could help.
    Bob
  6. #31
    Very Active Member Sopher's Avatar
    Feb 2008
    Just outside of Boston
    Looks like I need to replace my YUASA after three years. The original BRP battery lasted from 2010 to 2014. I put in the YUASA in October 2014 and this now needs to be pulled and replaced.
    It needs a battery tender EVERY night. I failed to do that once, and it would not turn over the next morning. I have missed that a few times and thus missed riding for the day.
    RT-S # 352; Timeless Black... faster than any other color. Mods: EasternBeaver PC8 Fuse Box, 12v digital dashboard display, RearTrunk internal Lights.
    Pioneer XMP3 hardwired, KewlMetal highway foot rests, PolkAudio Speaker upgrades (dxi525 & dxi400), Custom Garmin Nuvi bracket and wiring, Panel Savers, Custom LED array third brake light and rear signal LED's. Custom mud flap lights. Daytime Running Lights (3wattsx6). Heated Corbin seat with 'Lamonster' cut. JBL 400watt Amp,
    Other secret mods.
  7. #32
    Feb 2012
    Spring City,Utah
    Be sure the battery is fully charged before you install it. Don't rely on the dealer to have it charged,charge it your self on a slow charger.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  8. #33
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Sopher,
    Re: Looks like I need to replace my YUASA after three years.
    https://www.amazon.com/s/ref=nb_sb_n...TX24HL+Battery+
    I have a '08 GS & bought this; del'd on 4 Aug. The box said that it had been fully charged on 2 Aug.
    I put my Battery Tender Junior on it and nothing happened after about 6-7 hours. Took the BT Jr of & rehooked it up next day & about 2-4 hrs later it was fully charged. I say '2-4 hrs' because I was not paying that much attention; just noticed later in the day that the green light was on.
    In three years my Spyder has never started so fast.
    Jerry Baumchen
    PS) I bought my Spyder in the Spring of '14 & when it started hesitating on start-up last month, I decided that my three yrs were up.
    PPS) Before I bought this battery I called Yuasa and made sure that this was the one for my '08.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
  9. #34
    Jul 2017
    nh
    Default Battery removal vs battery tender 2012RT
    I'm in NH....should I pull the battery and store inside or connect Battery Tender? RT is stored in confined area so I'd have to pull battery in its final location..Would rather run battery tender to where it stays for the winter.
    Thoughts??
  10. #35
    Member ricrum's Avatar
    Jan 2018
    Campton, New Hampshire
    Quote Originally Posted by finless View Post
    Bob
    One little "helper" tip that I came up with while replacing my battery (2010 RT-SE5). Because the 2 terminal nuts are of the slide-in type (under the open-ended square terminal "bridges"), I set the nuts in place while the battery was on the work bench - and then cut two 3/4 inch square pieces of spare foam rubber, soaked them just a little with oil, and then squeezed the foam rubber pieces in under the nuts in order to secure them in-place while manipulating the battery back into it's holder. It works wonders. They act like a spring to hold the nuts up where they need to be, and the oil keeps the foam rubber from drying out and prevents corrosion from forming in that square cavity. Makes the job much easier.
  11. #36
    Mar 2019
    Rhode Island, USA
    Thank for sharing. It's very helpful.
  12. #37
    Aug 2015
    London, OH
    Default Super price on OEM battery YTX24HL
    Yuasa YTX24HL battery for $90. $80 less than dealer. Just installed mine.
    https://www.walmart.com/ip/YUASA-YTX...SABEgIwYvD_BwE
    Lots of lessons learned today as the official BRP service manual was completely incorrect as you will see I found out the hard way today.
    But in this video I also talks about a -BS battery (bottle filled) vs a OEM battery direct from Yashua.
    So please be aware of this fact.
    I went with the 24L-BS because I did not know about this issue.
    Personally I think it will be fine but I will let everyone know as time goes on.
    Anyway here is my video on replacing the battery and my experiences.
    I also show a trick to remove the mid-side panel off an RT without removing all the other panels
    Hope you all enjoy this video and that it was helpful to someone!
    Enjoy,
    Bob
  13. #38
    Sep 2019
    South Dakota
    Quote Originally Posted by Richard2762 View Post
    BikeMaster Lithium Ion 500 CCA DLFP-50N18L-A...$209.64.....Motorcycle PARTS 2U SKU:780831-TR
    Is it Lithium Ion or Lithium Iron? I have started replacing my batteries with the Lithium Iron from Shorai, I figured it has held up remarkably in my Ducati so far. Left the bike in another state untouched for over 6 months as I had gone to hospital and had to recuperate before I could go fetch it. Got it home and started right up! I just installed one in my Honda C70 with electric start and is great. I have one ready to go in my baby Harley next. They are in the 150.00 range depending on size from Battery Mart. I was getting the AGM Big Crank MADE IN USA from them for my full size Harleys and average 4 years life from them.
