What's the trick to getting the piston back in for new pads? The service manual says to "rotate the parking brake lever on the caliper to pullback piston". I can't budge it nor move the piston. I've even tried a c-clamp with no luck. Any ideas?
I think about a month or so ago someone else here had the same issue .......They made a tool that enabled them to rotate the piston in order to get it to back in..............I think .....Mike
I can't thank you enough for putting this up on the boards! I tried compressing the caliper piston on my 2014 RT Limited: to no avail. Then I remembered when I had my 2013 that I squeezed the brake and did something to the piston to get it to go in, but I couldn't remember what it was until I read you post today! You save me probably a couple hours and not having to go redo the brake lines etc... Again: Thanks!!!
I was wondering what the two holes are for in the head of the piston. Possibly for a tool to use to screw it back in, and it is all the way out, what with me playing with it. I've tried the tension lever on the back but it only goes forward and that extends the piston. Yet the service manual says to rotate back to pull piston in. So now I have to find a special tool to see if I can screw it back in. Weird, with my Goldwing I just compressed the pistons back. Oh, Yes I removed the reservoir caps to relieve any pressure.
remove the lever and turn the shaft counter clock wise.
some times you need a "C" clamp to get it back in. You need to open the reservoir especially if you added fluid at any time. Your park brake should be released and reset if adjusted due to pad wear. I don't recommend twisting the pistons just pushing them straight back. Twisting can danage the o rings...
Use a needle nose plyers to screw the piston back in. The plyers must be small enough for the ends to fit into the holes. Turn the piston clockwise as you push it in. Remove cap on reservoir to allow for over flow and place cloth around it. Good Luck!
So as a summery of what I have read here,if you have a 2013 or later use a pair of needle nose pliers to turn piston CLOCKWISE while pushing lightly in on it. With a 2012 and earlier use a C Clamp to push the piston back in. Remove master cyl. caps for room just in case and pack with rags to catch any overflow. Are there sny special precautions to be taken for the ABS brake system in changing the pads? I haven't heard of anyone mentioning any but you never know.
Did I miss anything?
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Remove the arm from the parking brake. Use a socket large enough to go over the threaded shaft that the parking brake arm bolts on to. 1 1/8" 1/2" drive socket. That will protect the parking brake shaft while using the C clamp. Position the C clamp so that the piston can be compressed, once snug open the bleeder valve while tightening the C clamp. Ensure that the piston is clean because brake dust can keep the piston from retracting. Compress the piston until flush, close the bleeder valve install your new pads and you are done. We have done it on two bikes this month and it is a royal pain in the rear end! Susie, I hope you have a helper.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Ann...
You can do that on the front calipers only.
But for the rear brake, you can't use that method on 2013 and 2014 models.
The piston is screwed into the caliper...
Sorry just noticed yours is a 2013....does it look like the one in the photo? It might be easier to rotate the piston.....or see if you can remove the round thing (bellcrank) that the cable is attached to, then turn the shaft.
If you tried a "C" clamp I will assume (risky as that is) you have removed the caliper and park brake cable. On the large plastic disc where the park cable connects you have a nut in the middle. Remove that nut,14mm I believe, and remove the disc this will allow the park brake to fully release. Now if it does not let you push the piston back it may be cocked at an angle (don't force it). If lines are still connected place a block of wood or old pads and a spacer then pump the brakes just enough to move the piston out a bit then try pushing it back. Must be even....
Nope that's no where near what it looks like. Here's a picture from the service manual. Since the real thing is in pieces. Resting on some wood under the muffler.
You should be able to unbolt that lever then and rotate the shaft....the part with the cable on top and spring on the bottom. don't use a C clamp until the shaft is retracted.
NEVER use C Clamp on that piston, It's self adjusting.
You just have to put 2 pins in the holes on the top of the piston and rotate the piston himself with a small bar or a big screwdriver. It's really easy when you have the trick.
You dont have to move the parking brake shaft at all.
Good Luck.
(Please excuse my bad english i'usely speak french)
This will not make you fell better, but I had the same issue last year with my 14. BRP changed the calipers in 13 and they no longer rotate back with the parking brake lever. I tried everything including the C clamp, but was unable to retract the piston. Do not bother renting the piston retraction tools from an auto store as none of the plates fit the Spyder piston.
I did try two punches that fit into the holes in the piston and a bar between them to rotate the piston, but was unable to move the pistion back.
What I finally did was remove the caliper and took it to my dealer who was unable to retract it also so they ordered me a new one and installed it under warranty.
I hope you have better luck!
2021 Sea To Sky, 2020 RTL
Isn't it weird that in AMERICA our flag and our culture offend so many people...... but our benefits don't?
It's exactly why i said NEVER USE A C CLAMP... You will broke the small thread between the piston and the caliper. The piston must act like a screw in a nut.
So, let me see if I have this correct...the piston on the REAR caliper on 2012 and prior models gets pushed back in and on the 2013/2014 models gets screwed back in?
