Results 1 to 10 of 10
Thread: Spare key?
    Active Member RockyMountainRider50's Avatar
    Mar 2014
    CO
    Default Spare key?
    Wanted to share some info about where to have your coded (chipped) key duplicated or cut. For standard non chipped/coded keys can be duplicated at Walmart, Home-depot and or Ace hardware. But they won't and can not duplicate a key that has a chip and needs to be coded. State-Wide Lock & Safe, Inc located at 7500 E. Colfax Avenue in Denver, 80220 (303) 333-0146 can and will cut or duplicate your blank Can Am Spyder chipped key at a reasonable price.
    Note: My dealer in Lakewood, Co. will reset the codes for your keys at a cost of $35 with appointment.
    2012 RT LTD & RT-622 , Pearl White
    Default Good to know..!!
    for those in your area..out here Kwick keys does the job nicely...thanks for posting....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Sep 2014
    East Texas
    Default Requirements to add "spare" key.
    To add a spare key requires both a key that is already programmed and a MASTER KEY available from a dealer. This will allow you to add another key. The MASTER KEY is for programming only as it is not cut to actually turn in the ignition switch.
    Very Active Member 2ndChildhood's Avatar
    Sep 2012
    Flushing , Michigan
    I had a key made without the chip so I could use it as a valet key. I lock my chip key into the trunk using the valet key. The blank key is a ilco number X270. I had to order them online. No place locally here had the blank key but had it cut at a local hardware. I will have some spare blanks at Spyderfest. PM me during Spyderfest if you want one.
    ToM
    SpyderFest '15
    Life is Great
    ToM
    Nov 2013
    Oro Valley Arizona
    Remember the 14 and 15 keys are different. 13 and prior will not work in 14 and 15. Most dealers only stock the 13 and prior keys.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Registered Users Gray Ghost's Avatar
    Harper, Texas
    Quote Originally Posted by Ben Burped View Post
    It is possible to have a key cloned for models prior to 2014. That process doesn't require the master key as the cloned key's code matches one that is already recognized by the bike. There were at least a couple of threads about a year and a half to two years ago that went into great detail about how to get it done.
    I am using a cloned key, haven't used the OEM key in almost a year now.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
    Sep 2012
    Flushing , Michigan
    Quote Originally Posted by jaherbst View Post
    Jack
    Thanks I didn't know that. The blanks I have works on the 2012.
    ToM
    SpyderFest '15
    Life is Great
    ToM
    Active Member Biosafena's Avatar
    Jan 2013
    Northeast Ohio
    Does anyone know what non-chipped blanks will work in the 14's??
    Sent from the corner of walk and don't walk...
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Biosafena View Post
    Same as 2013 and earlier. It only makes a difference for chipped keys.
    Bossier LoUiSiAna
    Many key issue solved with mykeyport.com
