Results 1 to 13 of 13
Thread: 1330 eng noise
    Active Member dbxray's Avatar
    Feb 2012
    Coeur d Alene ID
    Default 1330 eng noise
    Just wondering my 2011 RT seemed a lot quieter than the new 2014 RTL. there's a lot more engine noise coming up though the glove box area. When I say a lot more noise, I hear the engine more then the exhaust. Is this normal or do I have a problem
    Active Member ChicoFowler's Avatar
    Omaha, NE
    Could be a noisy fuel pump..... I have a similar issue, which I hope the dealer will rectify soon.
    Default Interesting..!!
    mostly hear about the noise from the fuel pump. Worth having the dealer check it out. If it is the pump the should have them and replace it if not they should check for other possible problems. Could be as simple as an exhaust leak...
    My impression is that engine noise is less compared to the 990 Rotax.
    Akspyderlady has also commented how quiet my 2014 sounds compared to her 2011 when we are going down the road.
    It does sound as though you have one of the noisy fuel pumps.
    Let us know if the fix is the cure, as far as noise goes.
    My 1330 is way quieter (and smoother), than my 998...
    Clermont, Florida
    I agree as well.. its very very quiet compared to my 2010 or 2012 Spyders
    Feb 2012
    Coeur d Alene ID
    Ok I will take in and have it look at. Will let you know
    San Diego. Ca.
    Every once in a while I hear what sounds like a fan blowing, is that a fuel pump issue or a cooling fan coming on?
    Default Fans..!!
    Quote Originally Posted by Jdsd1 View Post
    That can well be your fans. They wll reverse when you are stopped in traffic to keep the heat away from you...
    San Diego. Ca.
    Thanks that it
    USA, Alabama, Leeds
    Default 2014 RT Ltd noise
    Mine clatters when 1st started until the lifters pump up..... just a couple of seconds..... then it's quiet (after I had the fuel pump replaced).
    Mar 2011
    Hammond, Louisiana
    Quote Originally Posted by dbxray View Post
    What did you find out at the dealer?
    Feb 2012
    Coeur d Alene ID
    Quote Originally Posted by Dar View Post
    They said it was find
