Results 1 to 15 of 15
    May 2013
    Edmonton Alberta, Canada
    Default Winter Farkle Time!
    Had a chance to do a little Farkleing!
    Have to thank Deanna777 for the inspiration for Farkle #1
    Painted my Dashboard Bezel
    Had a chance to put on my Spyderpops Stainless Grilles & KOTT Grilles
    I'd also like to give a shoutout and to Finless Bob for his video on replacing the Spyder Speakers, probably saved me a week!
    And this little gem is a pic of just how far you have to go to replace the saddlebag cargo module, I don't recommend this!!! (rear speaker not part of this tear down)
    2014 RT-Ltd , Cognac
    Default Congratulations..!!
    looks great. The dash is awesome and always liked the grilles. But winter is not over..what else..??
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Sep 2014
    mathias,wv
    Default Looks very nice
    Great job!
    [SIGPIC]
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Did you use OEM paint on the dash or did you find some other paint that matched
    I want to do dash and rear fender
    Don
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Vermont
    Quote Originally Posted by garb55 View Post
    Don
    I used VHT High Temperature Engine Metallic Drive Train Paint Chemical Resistant Coating. Sent a pm Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    May 2013
    Still working on the speaker upgrade, powder coated windshield bracket and I just ordered the Top Case Mirror from Doc Humphreys.
    May 2013
    Don
    VHT high temperature Engine Metallic SP402 Burnt Copper + Clear Coat
    Default YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SSSSSSSSSSSSSSSSSSSSSSSS
    Quote Originally Posted by Purple Guy View Post
    ....Since you have used this Paint and seen it close up and personal , do you agree that it is EXTREMELY close to the OEM Cognac color.........The only thing I did different was to keep the area directly around the instrument cluster FLAT BLACK, to prevent any glare possibilities..........I found this paint awhile back and used it on my RSS ( after buffing the shine out ).....I then convinced DEE that with a few coats of CLEAR in would deepin the shine effect............I think it really makes the Dash surround POP..................Nice job.........Mike
    May 2013
    The color match is spot on! At $15 a can how can you go wrong!
    I thought about leaving the part closest to the gauges black as well, after the first couple coats.
    I like the look I have though and if glare becomes a problem it will be an easy enough fix.
    Default PER CAN------------------------------WOW
    [QUOTE=Purple Guy;930134]The color match is spot on! At $15 a can how can you go wrong!
    I like the look I have though and if glare becomes a problem it will be an easy enough fix.[/QUOTE.......................Only $ 8.50 here, but if you actually used BRP paint it would have been $ 50 + at least..............glad you liked it ,,,,,,Mike
    May 2013
    [QUOTE=BLUEKNIGHT911;930520]
    $8.50 USD, that's just short of $100 CAN!
    A beautiful paint job.
    Vermont
    Thanks you, thank you, thank you, Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Active Member Dubld's Avatar
    Mt. Pleasant, IA
    You inspired me! That dash really pops! I ordered the paint to do mine.
    2014 Cognac RT-S SE6 "Rusty"
    Jun 2015
    Los Angeles
    Had a chance to put on my Spyderpops Stainless Grilles & KOTT Grilles rohana wheels
    And this little stance wheels gem is a pic of just how far you have to go to replace the saddlebag cargo module, I don't recommend this!!! (rear speaker not part of this tear down) tsw wheels
    NICE WORK!!
