Results 1 to 25 of 37
Thread: Install time
    Sep 2014
    Grants Pass, OR
    Question Install time
    I have ron's sway bar and was going to try and have the dealer install it for me. What is a reasonable amount of time to install? They quoited me 4-5 hours minimum. From the posts I have found on the forum I thought it would be about half that. Has anyone had their dealer install and what was the price range? Thank you for any information.
    Jun 2013
    queens ny
    my dealer installed it for free when my bike cam in, but he also told me it took them 3 hrs to do it
    Sep 2014
    Grants Pass, OR
    Quote Originally Posted by cuznjohn View Post
    Thank you for the information. This was my first Spyder so didn't know what to ask for when I bought it . I haven't met any spyder owners in person yet so am kind of learning as I go.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Central FL Powersports charged me 1.5 hours of labor to put on the sway bar when I got a laser alignment. Only thing I missed was getting the aluminum links, which are recommended for the stiffer sway bar. I am adding them myself.
    Four to five hours seems excessive, but perhaps they don't have much experience doing it. I don't agree that you should be paying for their training. Check with other dealers that are a reasonable distance from you, if you have any.
    Bryant, Arkansas
    1.5 hours is plenty long enough to install the sway bar and links.
    Cruzr Joe
    Nov 2012
    North Las Vegas, NV
    It's not that hard to change it yourself.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2013
    Richardson, Tx
    I installed one myself taking my time with it from start to finish only 1.5 hrs
    Default Depends..!
    on how they go about it. 1.5 hr's is plenty but shops may claim more depending on the shop rate for changing the sway bar.
    Sep 2014
    Los Angeles
    Default Install time
    I'd say 1.5 hours is a good start. This included getting the front tire Car ramps on the RSS. I have seen pictures of far too much stuff being taken off to do this. I just loosened the Frunk and put that 2x4 like in the video and removed the skid and I was done in an hour. Following weekend I decided to install the billet links to make sure I had no issues. That didn't require any removal of anything, just pulled the bolts and put the new ones in. 30 minutes.
    Sep 2014
    East Texas
    Default Hello
    Quote Originally Posted by hognut View Post
    This was your dealers way of saying "don't bring something that you bought somewhere else in here for me to install and possibly have to warranty". 4-5 hours was their way of saying "take a hike". Sorry to be the one to tell you.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Quote Originally Posted by GunDoctor View Post
    My understanding (from this forum) is that RTs have to be about 2 feet off the ground for adequate clearance to replace the sway bar. That's why I had the dealer do it. It may not be difficult, but if you don't have the capability it's a moot point.
    United States
    That's what I thought, too! Putting Ron's sway bar and the links took about 1 hour on the lift for my '14RTS.
    Quote Originally Posted by Ben Burped View Post
    Invalid Emails
    Oct 2014
    Dillsboro, IN
    Default inadequate sway bar?
    Is the sway bar on the "14 that poor that it needs replacing? Seems on this model, that should be a rock solid item.
    2015 RT Limited , Pearl White
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Quote Originally Posted by GreenDragon View Post
    Adequate is a better word. My 14 was twitchy on the road when I bought it, it tended to wander around in a lane, and going through turns was an exercise in constantly adjusting the turn radius.
    The new bar took care of that. I don't have to worry as much about the wandering. It also moves less in truck wakes or vortices from vehicles passing in the other direction.
    I did it since I had the opportunity for the dealer to get it done. I am glad I did. The stock bar may be fine for many, but the numbers of forum members who have changed it and gave it positive reviews swayed me.
    Harper, Texas
    They are probably quoting taking off the frunk. The swaybar was the first thing I ever did on my Spyder, don't remember the exact time but it definitely wasn't 4-5 hours.
    My dealer took 1.5 hours to do the job as part of the OTD price, labor rate was discounted also.
    Your dealer probably has never done a sway bar swap before. 1.5 hours labor is fair. Anything over 1.5 hours is too much.
    The problem is that the BRP manual says you have to remove the Frunk to change the sway bar. Not true, not necessary and adds a lot of unnecessary time and effort to the job. Some dealers will listen to reason, other will quote the manual like it is the Holy Grail.
    Someone who knows what they are doing can do this job easily in 1.5 hours. Especially with a lift. If they are really good at it, it will take them well under 1 hour.
    If you can talk your dealer out of pulling the Tupperware and use the instructions that come with the bar they should be able to do it in 1.5 hours.
    After-all, they are Highly Trained Professionals... Right!?
    Good Luck!
    Feb 2009
    Canby, OR
    If I had a proper lift, and was a bit more limber, 1.5 hrs would be reasonable. However, I don't, and am not, so it was more like three hours.
    Jul 2010
    Las Vegas, NV
    Default DIY
    Try. Or, bring it here. I can do it in 1.5 hours! Everybody needs a trip to sunny Las Vegas!
    Joe Meyer
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Sway Bar?
    I have a 2014 RT-S and did the install myself. Also, did a friend of mine as well. It took me about 1.5 hours, total time, to change the first time. Second time much shorter. Also put one on my ole 2011 as well. Try it yourself, not hard, just follow instructions. Have fun
    2014 RTS SE6 , Cognac
    Jun 2013
    Cleveland,OH
    Ron includes great directions, I installed new links and the sway bar myself.
    Sep 2014
    Grants Pass, OR
    Default Thank you all
    Thanks for all the information. I bought the roll bar with the intention of installing it myself, but am having a problem with getting the 20-24 inches clearance and my getting up off the floor . I am planning on getting the laser alignment at the Redwoods Run so may bring it with me and see if I can get it installed then. Again that you all for the information.
    Oct 2014
    The Dalles, Oregon
    Can't wait to get my bar installed. As soon as I get the height figured out and some warmer weather as mine will be done outside. Pretty sure I can do it with the good directions that came with it. Probably take me at least 2-3 hours
    Invalid Emails
    Sep 2012
    Hunter Valley, Australia
    Pre 2014 models were/are much easier to install than the 2014s. About 1/2 an hour vs about one and a half hours.
    Mar 2013
    The hard part was getting the hight to remove the stock bar and install Ron's bar.
    What I ending up doing was using my Sears red lift that has a hight of 18 1/2 inches at max lift and lifting the Spyder high enough to put my car ramps under the front tires. I then lowered the lift to it's lowest point. I then stacked two 2x10x18" wood pieces onto the lift so that they rested along the frame and raised the lift to it's Max hight. This gave me 21 1/2" and was just high enough to do it.
    If I was to do another one I would pick up a 4x4 piece as that would provide 22" and make it easier to do
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
