2014 RT Tupperware removal
I noted that the side panel removal was very similar to my 2010 - is that true for most/all of the 2014 RT tupperware? I have a "Green" shop manual, and there's nothing about tupperware removal in that manual - but Lamont still has videos about tupperware removal for earlier models.
I'm getting ready to install the fog lights, and would really like to see what I'm in for, before starting... just me. Perhaps someone could point me to a tupperware removal document???
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
This is a pretty good video for tupperware removal...
Another good resource from our friends down under.
PLUS PART # 2
Removal of all Tupperware is the same except for the Frunk. The air hose on the left side has to be disconnected at the screw clamp just under the front left corner of the Frunk. The electrical connectors should be located just under the two triangular plastic panels that are removed to hook up BUDS.
Can the fog lights be installed w/o removing the frunk - just the upper tupperware around it??
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
Nope, your gonna have to remove the frunk. The lights actually mount inside there and you will have to partially disassemble the frunk as well to get to the mounting locations.
Sold my 14 RTS went back to 2 wheels.
2014 Kawasaki Vaquero SE
Might be more than I want to chew - - -
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
