Results 1 to 25 of 30
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Default Needed: Flexible Helmet Lock Extender
    I've always used the standard helmet clip under the seat to store my helmet when I'm away from the Spyder for a short time. But recently I got a new helmet, and the D-ring side of the strap is too short to fit. A standard T-bar helmet lock extender will not work on the spyder under the seat. Anyone know of a flexible helmet lock extender that will work... perhaps made out of leather or canvas, etc.?
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Very Active Member Oldmanzues's Avatar
    Mar 2009
    Beavercreek, Ohio
    Just a idea, do not know if it would work.
    A small "carbinner clip". They look like a flatted oval and and have screw opening/shutting nut.
    A loop of cloth jus long enought to accomplish hooking one end over the seat hook, thru the D ring then bck to the seat hook.
    I just keep enough room in my frunk for my modulal helmet
    Good luck
    Oldmanzues
    Very Happy Spyder Owner
    May 2013
    Edmonton Alberta, Canada
    Just as another option, I have a Helmet Guardian and I love it.
    Personally I'm not a fan of hanging my helmet on the side of my bike.
    2014 RT-Ltd , Cognac
    Default Here's what you do..!!
    hardwear store...piece of garage door cable... Two crimp cable locks...make an eye loop at each end...run it thru the "D" ring hook both eyes under the seat...done. In a bind use a big zip tie...circle cable is even easier than the two eyes. One clamp feed it thru the "D" rings...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Bryant, Arkansas
    Another thought ............................ DO NOT PUT YOUR HELMET ON THE CLIP UNDER THE SEAT ........................ You will scratch the Spyder, This is experience talking, put the helmet in the side saddlebag (the right side saddlebag is a little larger), or in the frunk.
    Cruzr Joe
    Orrrr... keep an eye out in the Harley catalogs. (They've always got the FUNKIEST stuff available!) You might find exactly what you want in one of them.
    Oct 2013
    Pottstown, PA
    Default Thanks, Guys!!
    Thanks guys. All good ideas. I appreciate the responses.
    Joe, I'm sticking the helmet in a compartment now, but I'm planning ahead for taking some road trips this season. My storage compartments will be full and I'll still need to secure the helmet.
    Purple Guy, that Helmet Guardian is a nifty idea - never seen that before.
    Gene, your idea is simple to use, and I'm really into "simple". When not in use, I can store that cable under the seat where it's handy. Thanks for suggesting that. Think I'll pay a visit to Lowes or Ace Hardware this weekend. I'm hoping they'll even have a crimping tool I can use so I won't have to buy one. I'll look for some soft plastic coated cable to avoid scratching.
    I also found this on Amazon for about $6. It expands from 4.5 inches to 6 feet. Not suitable for the helmet, but I'm sure I can find a practical use for this while on the road.
    Rob
    2013 RT Limited
    Cruzr Joe
    I'm in the 3/32" cable club, shielded with heat shrink tubing and crimped with a ferrule and stop set. Cut a slit in a small piece of chamois, put the slit over the clip and the loop of cable through the D-ring with the ferrule hooked on bottom side of the clip. Chamois protects the paint both where the helmet rests against the Tupperware and, most important, where the cable hangs down between the closed seat and Tupperware.
    Active Member markyodo's Avatar
    Columbus, OH USA
    There is a thread started for the Kewlmetal locks.
    http://www.spyderlovers.com/forums/s...l-Helmet-Locks
    I would love to find a set of these if they still make the adapter for the RT grips.
    Our Scenic Life - Spyder Videos
    https://www.youtube.com/channel/OurScenicLife
    Ask me about my Spyder.
    2014 Black Can-Am Spyder RT
    Active Member Noral's Avatar
    Brandon,Ms
    Quote Originally Posted by robmorg View Post
    Go to your local police dept and get a gun safety cable they are free for the asking.Good luck. This is what I did and they work.
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    I have to say, I do LOVE my Kuryakyn grips with helmet locks on each end! No seat hassles.
    Also that "hook" under the seat is plastic. I figured if someone wanted my helmet bad enough they could pull hard and bust that off?
    Someone also pointed out that with the Kuryakyn helmet locks, someone could cut the strap and take off with the helmet. But pretty sure that makes the helmet unusable at that point. The person that pointed that out uses a helmet cable lock and runs it through the chin bar (full helmet) and then around the base of the handlebars. So I guess if you want to be real secure, that is the way to go.
    Bob
    2011 RT-S SM5 - Black
    Oct 2013
    Pottstown, PA
    Bob, were you able to find the adapters you needed for the hand grip locks?
    Rob
    2013 RT Limited
    Active Member nakerr's Avatar
    Fort Saskatchewan, AB Canada
    I use a 6' long, very heavy, bicycle lock cable with a hardened padlock. Although it is long for just a helmet, I can tie up two at once as well it is long enough to go through the sleeve on my "expensive" riding jackets thus enabling me to leave them on the machine as well.
    YMMV
    Norm
    ...Not All Who Wander Are Lost" - Bilbo Baggins
    2015 RT-S SE6 Special Series
    May 2013
    Stanton, ca
    I installed the Kuryakyn grips and thus bought the stock Kuryakyn helmet locks that go on them. No adapters needed.
    Way back I had seen the adapters for the stock RT grips to enable mounting of the Kuryakyn helmet locks. But I did not like the color mismatch and the Kuryakyn helmet locks don't come in black. Had they, I would have kept the stock grips and gone that way.
    Bob
    Registered Users Gray Ghost's Avatar
    Harper, Texas
    They won't keep someone from taking the helmets but for hooking the helmets to the OEM clips we use some straps from Camco for securing awnings on RVs. (http://www.amazon.com/Camco-42503-12.../dp/B000EDOSSI) We hook the d-ring over the plastic clip and run the strap through the helmet d-ring.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
    Very Active Member Buggy's Avatar
    Ontario Canada
    Quote Originally Posted by Purple Guy View Post
    I bought one of these as well and second that it is great. intrusive and bike safe, ie no marring.
    2016 RT Ltd. , Pearl White
    Active Member Mr. Bill's Avatar
    Simcoe, Ontario, Canada
    What I found that works to lock the helmets and leave them on the seats was a "cable luggage lock" . Google it or check with your local luggage shop. The TSA cable locks sell for about $8.00. Leaving the helmets on the seat does not mark up the side panels and keeps people off your Spyder while you are away from it. I run the cable thru the rear hand grips and thru the ring on the helmet strap ring. Works for me and I don't find boot marks on my saddle bags or anyone sitting on my Spyder when I return.
    cable lock.jpgTSA Cable luggage lock.
    2013 RT Ltd. Black Currant, SpyderPops Bump Skid & Belt Guard, Bajarons Sway Bar & Heim Joints, BRP. Trailer Hitch, Trailer Hitch Luggage Carrier, Cat By-Pass, Wrapped pipes, Custom Dynamics HMT Brake light & Dual Brightsides, F4 Customs Windshield, Ultimate Tallboy seat & back rest, Rivco Armrests, LED mirror lights, Lidlox Helmet locks, Elka Stage 2 Frt. Shocks., Clearwater "Darla" LED driving lights, Tricled LED headlights & fog lights, Tricled fender LED lights.
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    I saw this on somebody's Spyder once, but my concern was that the bolts holding the guardian itself on could be as easily removed as my license plate in a minute or two. Did I miss something about how it actually attaches to the Spyder?
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I bought these helmet locks from KewlMetal . Helmet locks made for the bar ends of the RT. I love them they work great . I bought the two and they came keyed alike for convenience. Here is the link on spyderlovers for the thread.
    Read what others say about them
    I found my shipping invoice and the part#526 helmet lock with adaptor I just bought these Feb 2013
    May 2013
    Stanton, ca
    Quote Originally Posted by Marker View Post
    You cannot get those anymore per the other thread that is talking about them.
    The guy that made them no longer is part of KewlMetal and now makes specialty grip end helmet locks per the other thread discussion from today.
    Bob
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by nakerr View Post
    YMMV
    Earlier in this thread I had said that I just picked up this coiled cable on Amazon. It was inexpensive, and at only 4.5 inches long, easy to store. Yet it expands to 6 feet. I'm thinking it may come in handy once in a while, like to briefly secure my jacket and/or other gear on the seat while on a road trip when the luggage compartments are full.
    Rob
    2013 RT Limited
    Invalid Emails
    Aug 2010
    Quote Originally Posted by finless View Post
    Bob
    Did not realize this ,Thanks
    I really like the locks , and they work well.
    Just read the other post and here is the link for the new helmet locks that Lamont discussed in his post http://lidlox.com/
    Vermont
    Cruzr Joe
    I agree, I would do the same thing. It is safer, and under lock/key. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Oct 2013
    Pottstown, PA
    You cannot get [the KewlMetal grip locks] anymore per the other thread that is talking about them.
    Bob
    BUT... As the other thread progressed further, Lamont posted a link for the new company, started by "Matt", the guy who used to make these for KewlMetal. And they are even better now. They now fit right on the Spyder grips without the need for an adaptor. These things are cool!
    So... While I sincerely want to thank everyone who posted in this thread giving me great options for extenders to work with the under-seat helmet clips, I have decided to go with these hand grip locks from Lidlox. And Joe, no chance of scratching up the side of the Spyder with these locks.
    Here's a picture showing what they look like...
    Rob
    2013 RT Limited
    Bossier LoUiSiAna
    Redneck way flexible cable gun lock & or kiddie bike lock. Like $5most stores will fit thu the D rings, most are long enough to loop wherever u wanna try, G'luck[emoji106]
