Help with Tri-Color Magic Channelz wiring please?
Currently attempting to install Custom Dynamic Tri color Magic flex Channelz with TIPZ unit. Stumped with wiring. Instructions stated when installing Channelz with Tipz unit connect Red to red and Black to Black BEFORE the TIPZ unit. So I did. Connected those colors to the front fender light/LED. Complete! Right or wrong? Then it states to connect the yellow wire to the turn signal. By following the instructions in owners manual page 107 and removing instrument cluster. Couldn't find it in shop manual nor owners manual. So I connected the Yellow to the colored wire in each of the turn signals with no success after turning on to test. Mud flat and Brightsides work as running and turn signal but Channelz don't work. Now I'm stumped. Any suggestions? Thanks in advance for any and all responses.
I'm also looking to get these very same lights for my RT, so I hope someone has some great advice for you (and Me)! That would help us all out...Good luck!!!
~'12 RT Limited, Pearl White~
BajaRon Anti-sway Bar
Squared Away Laser Alignment
Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
Lidlox Grip Tip Helmet Locks
TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
Palmer Signs Custom "Captain America" frunk graphics
Twisted Chrome Pinstripes
Overland Australian Sheepskin Seat Cover
I agree!
[QUOTE=NorCalBud;922638]I'm also looking to get these very same lights for my RT, so I hope someone has some great advice for you (and Me)! That would help us all out...Good luck!!![/QUote
Thus far my attempt to install C/Dynamic TIPZ Unit, front Mudflap lights, and Brightside amber has been a success. Also changed the OEM bulb in the fender tip! The Magicflex Channels wiring has caused the delay. With only three colors of wires (Red, Black & Yellow) it has slowed my progress. Needing to find out where the instrument cluster is located. Instructions for magicflex Channelz state that on page 107 of owners manual you must remove the cluster and attached the yellow wire to the appropriate directional/turn signal. Still looking for the instrument cluster.
GY/Pk is left
Bk/Ye is right..
That is for a RT..
Thanks! But not sure what that means?
those are the wire colors for the front left and right turn signals per the wiring diagram..
Turn Signal
On my RT I connected them to the turn signal wires. They can be accessed by removing the mirrors or taking the instrument cluster panel out ( that is the panel with all the gages and tach in it.
Otis Almond CW2
US ARMY RETIRED
Police Officer Retired
2011 Black RT SE-5
2012 Red RT-S SE5
Thanks for your suggestions! All off you have been very helpful.
