2014 Yamaha Bolt
I have a 2014 Yamaha Bolt in great condition, White, Aftermarket exhaust, I bought this with the intention that my wife would ride it, I was wrong. asking 5,995.00 OBO, No lowballs please, I need to sell ASAP. 5,700 miles, current tags and inspection.
Dimensions
Length 90.2 in.
Height 44.1 in.
Width 37.2 in.
Weight 540 lbs.
Ground Clearance 5.1 in.
Wheelbase 61.8 in.
Seat Height 27.2 in.
Engine
Engine 4-stroke, V-twin, SOHC, 4-valve
Displacement 58 ci (942 cc)
Bore x Stroke 85 x 83 mm
Compression Ratio 9:1
Fuel System Fuel injection
Fuel Tank Capacity 3.2 gal.
MPG Rating 51 mpg
Ignition TCI (Transistor Controlled Ignition)
Clutch Multi-plate wet
Cooling Air
Drivetrain
Transmission 5-speed
Final Drive Belt
Brakes/Wheels/Tires
Brakes Front & Rear: Wave-type disc, 298 mm
Tires Front: 100/90-19M/C 57H
Rear: 150/80-16M/C 71H
Operational
Suspension Front: Telescopic fork; 4.7 in. travel
Rear: Dual piggyback shocks; 2.8 in. travel
