Page 3 of 3 FirstFirst 123
Results 51 to 62 of 62
  1. #51
    Oct 2007
    Yes, please enlighten us!
  2. #52
    Feb 2015
    Diamond Bar, Ca.
    Default oil change interval & type
    My new F3S Spyder with the 'wonderful' 1330 engine has the first oil change & service at 3,000 miles & the second service at 9,300 miles
    so you can see that they don't suggest a 9,000 mi interval. What I'm not sure of is the type of oil, blended or full synthetic, that it comes
    with or that you should continue to use. Also, Is it true that you shouldn't mix the two - what if I need to just add a little=what type??
  3. #53
    Default THIS MEETS AND /OR EXCEEDS ALL BRP REQUIREMENTS
    Quote Originally Posted by DB Dan View Post
    DB, I also have the 1330 Ace engine and use the Rotella T-6.... 5w-40 Full Synthetic...$ 22.40 per Gal. @ Walmart ( DO NOT USE THIS IN THE 998 engine ).....I don't know what the F-3 servicing TIME requirements are , but even with Synthetic I wouldn't go more than 5,000 miles without changing it .....Mike
  4. #54
    Northern Kalifornia
    Default 9,300 oil change
    BRPcare
    • Also, much confusion about oil change interval---after the initial break in service at 3000 miles, is the next oil change done at 9300 miles or 12,300 miles??
      From the operation's guide, the break in for service is 3000 miles. Other maintenance intervals are every 9300 MI or 1 year - whichever comes first. In other words, the first time the unit has its service done the unit will have 3000 miles. Then, the first regular maintenance + next oil change will be at 12300 miles (9300 miles after the initial service). Afterwards, every 9300 miles should continue to be the norm.
      Hope this helps answer your questions.
    Steven M.
    Customer Satisfaction, Social Media / Dealer Tech Support Team Lead
    BRP
    Follow us on Twitter @BRPCare
  5. #55
    Danbury Connecticut
    Last word ?
    4,100 views of the LAST word ?
    I'm sure glad we got that one resolved.
    Is there a last word on tires ?
    IBA #47122
    2020 RT Limited Asphalt Grey
  6. #56
    Northern Kalifornia
    Default 4 what it's worth
  7. #57
    Oct 2007
    Default accidental dislike
    Sorry 2dogs, accidently hit dislike when going for thanks button. New to site, don't know how to undislike something.
  8. #58
    Northern Kalifornia
    Default LOL
    Quote Originally Posted by ACE1330 View Post
    OK....
  9. #59
    Default THIS OIL VIDEO
    Nice (?) video , But I hope everybody realizes that the oil they are wowing about is not the OIL you get when you ask for the " oil & filter kits " at the dealer.......That oil is BLENDED OIL.........................NOT " FULL SYNTHETIC " which is what they show you in that video and state is tested to the MAX.......they say nothing about the BLENDED OIL ................WHY ???????................think about it ......Mike
  10. #60
    Feb 2015
    Diamond Bar, Ca.
    Cool Apologize for wrong info
    I stand corrected & apologize for interpreting the manual info reg oil change interval incorrectly.. per the manual & my servicing dealer it does appear to suggest changing oil at 9,300 mi intervals after the initial 3000 mi change...<***>...So Sorry!
  11. #61
    Jun 2011
    Near Lexington, NC
    Default Lab test of Motul 7100
    Just got a report and the details can be found here if you're interested: http://www.bobistheoilguy.com/forums...l_#Post3688507
    In short, Motul viscosity had dropped down into the 30W zone so I changed it out with Mobil 1 to give it a try. So far, of the various oils I've tested, Amsoil has the edge. When I run out of Lab test bottles, I'll go back to using Amsoil as my preferred oil.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
  12. #62
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by ulflyer View Post
    Thanks for posting. Always interesting to see actual factual data.
    I am so glad that we no longer need to waste any more time or energy on this subject since we've come to ... 'The Final Word on 1330 Oil Changes'.
