Results 1 to 5 of 5
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Default extended trans filter
    hi the standed trans filter is # hf559 what number is for the extended trans filter?
    richie spyder
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by ssmcclub View Post
    The only manufacturer of the extended trans filter is BRP. No one else makes that filter.
    Default Don't know..!!
    but most dealers only sell the longer filters. If you don't have the extended cover they will provide you one....
    ​2012 RS sm5
    Aug 2007
    Greeneville, TN
    True. But if you do not have the extended cover you then have options. Much less expensive options that have been 100% reliable with zero issues.
    Apr 2013
    massapequa ny 11758
    ok thank you
    richie spyder
