2014 rtl tires
I'm looking for new tires to change out the stock kendras dealer changed both front tires and i still have a slight shimmy in the front had laser alignment helped added elka and sway bar helped a lot but i've decided that it's time to change tire brand, looking at the kumho brand ast 195/50R15 front with 225/50R15 rear will they work without setting codes??? thanks
NO WAY
I have 185/55-15's on my fronts and there is no EXTRA SPACE,,,,, they only just fit .............You have done a lot to cure your problem .......But I think you should have started with a High Speed Spin balance ........any car tire place can do it ......just bring them the wheel and tire .....................Good Luck, Mike
sorry i forgot to mention that i did that after the dealer replaced the tires i added the bar and elkas and that brought out that the tires were still not right,when i talked to len in mo. he said to try spin balance they were off by 3/4 oz. So that is why i'm thinking of changing tires.i'll look at other sizes for the front.thanks...also iforgot to ask anybody know what the tire dia. are front and rear thanks
Reason: added more infomation
tire size
150/80/17 is 26.45" in dia. and 160/70-17 is 25.82" in dia.
Dray
WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAT
I have Federal EVO tires on the front of my 2014 RT Limited.. They are the same size as the poem and have lasted 18000 miles already with great handling and little or no wear.
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
I think some people are running Federal Evo tires on the front of their 2014. I am running a 215/60/15 on the rear with no problems.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Hi Doc,
How do those EVOs "feel"?
What's the ride quality like?
Hi Doc,
The tires feel and handle great. Much better than the oem kendas
Thanks!
We had one earlier report (from Guzzi?), that indicated a dis-satisfaction with ride quality.
bouncy tires
I had same issues. When I picked the bike up from the dealer they were HORRIBLE, took them back within the hour and they "rebalanced" them and they were no better, took to auto shop next day and they did the balance on the big expensive new high tech machine, took off a lot of weights, added some in other places and it was much better, cost $32, rode home the 200 miles and static balanced them in my own garage using the Marc Parnes wheel balancer, which I have used for many years and they are perfect, silky smooth
http://www.marcparnes.com/BMW_Motorc...l_Balancer.htm
Andy
My wife and I circumnavigated the globe on our trimaran sailboat, gone 8 years
Cushman Eagle, 1954 Corvette, 1964 Corvette with Duntov cam, 1996 Corvette, Chrysler 300 Hemi,
2003 1800 Gold Wing with Hannigan sidecar
2014 Spyder RT
IBA41956
DS446
fixed
this morning i put ride on tire treatment in tires 10oz front 12 rear vibration is gone with wife on the back no vibration at all even at 80mph much better thanks to all replys....
Federal Evo's
What air pressure are you running in the front federal evo's?
Greetings from Idaho
2014 RT-S,
Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
2014 RT , White (Mine) Cognac (wifes)
The rear tire I have 215/60R15 - General Altimax RT 43 no problems/ and I did not notice any difference, the spyder handles fine on dry/wet pavement. I did not get any hydroplaning, the tire gripped the road.
Yesterday mike( blueknight911) and I were riding on some wet pavement and going thru some twisties. When it comes time to replace the rear tire in the future, I would replace the rear tire with an other General Altimax RT 43 ( if they still make it). Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Good Price on Federal Front Tire 165-55-15
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
