Frustrated
I can not remove the cover between the taillights on my ST. I removed the one screw right in the middle of the cover but there must be a second one that I can not locate. Anyone know where it is located?
Thanks,
ShadyGrady
tail light cover
I think you mean the tailpiece - the one on top of the lights? Yes, only one screw. They say to insert a screwdriver into the edges of the tailpiece (carefully) to kind-of lever it out. Fingernails do, too. It says in the manual: Using a small screwdriver, release the upper tail cover tabs.
...in the pink (Girls On Spyders)
Mark had a booger of a time with it....do as loisk says...be careful
#IamARyder #RideASpyder #CanAmSpyder
THANKS!
Thanks guys. I could not believe there was not another screw, but you were right. Man, that is a tight press fit! And you are also right about being very careful - it would be VERY easy to scratch your paint.
Thanks,
ShadyGrady
Agree..!!
always good to have a nylon or plastic pry blade for these things. Take your time and if you feel anger building...walk away..!!
2012 RS sm5
Any problems (heat) with the 2013 ST-S ?
Found great deal on 2013 ST-S but was concerned with all the problems of this year model.
Go for it!!
I have a 2013 ST-Ltd. I had some heat issues, but nothing that ever stopped me from riding on high temp days or anything that I thought was dangerous. Best of all it only took me one phone call to BRP to have them ship replacement (2014) panels with revised air inlets. I am certain this will still apply. If you are buying from a dealer he should be aware of it. My panels were installed by dealer (and shipped to dealer) at no charge as I was there for a service.
Good luck
