Results 1 to 13 of 13
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    Default Ground Loading Motorcycle Trailer
    This won't haul a spyder but they make them that will. Some of you might have other bikes you need to haul. Here is my listing
    http://dallas.craigslist.org/ndf/mpo/4792034361.html
    Thanks for looking.
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    I have a question about the technology of this trailer, not your specific unit for sale.
    It appears the trailer is disconnected from a tow vehicle to load it. Once you have done that, how do you reconnect to the vehicle? There is no way you will lift the tongue with a motorcycle on it.
    Having seen ads for these, I am curious how you handle the trailer once loaded.
    Default WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAT
    Quote Originally Posted by MisterP View Post
    ...I'm 67 and not any kind of superhuman 67 and I pull my 425 lb. trailer with my 2014 Spyder RT on it ......The load just needs to be balanced .....It's not like a wheel barrow !!!!!! ...........................Mike
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    A properly loaded trailer typically has 10-15 percent of it's weight on the tongue to prevent sway.
    If you can pick up yours that easily, I would suspect the tongue weight is too low.
    I didn't ask how the trailer is moved, but with my back I would not be able to lift a trailer with 100 pounds or so on the tongue to put it on my car. I also did not see a trailer tongue wheel on that trailer, which on hard pavement would make it easier to roll around.
    So I asked. I am very aware of the differences between a trailer and a wheelbarrow, thanks for the education.
    Default As I see it..!!
    you can load the vehicles with the trailer attached to the hitch. They do make them for the spyders as well and looks like a nice set up and at a reasonable price. To bad I have no two wheelers...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mod Monster Phil's Avatar
    Nov 2010
    Tyler, Texas
    Razor has videos on their website showing how it works. I'm likely going to get them to make one that will handle 2 RTs. He's done the engineering and tells me it will work well. The winch will be powered.
    http://www.razortrailers.com
    ____________________________
    Phil - Tyler Texas
    2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
    Feb 2013
    In my listing there is a link to a youtube video that explains.
    Ed
    Feb 2013
    I'm 70 and had no problem lifting the tongue to connect to the hitch, but if you are positioned correctly it will come down right on the hitch and you won't have to lift anything.
    Ed
    Jun 2014
    Schenevus NY
    Looks like a real clean, simple design. Have to make a note of this.
    Trb--
    Interesting...
    Active Member cougar's Avatar
    Alpharetta, GA
    Looks like a trailer made in Blueridge , Ga.
    Nov 2014
    canton, ma
    It is made in blueridge. I have one that gary is building now for my 2014 RT Ltd. Hope to have it shipped to Mass. Soon.
    Alpharetta, GA
    Ikin,
    Post some photos here when you get it.
    cougar
