Page 3 of 3 FirstFirst 123
Results 51 to 62 of 62
  1. #51
    Registered Users krb1945's Avatar
    Apr 2009
    God's Country, Keystone Heights, FL "Happy Owner"
    Default They arrived yesterday
    I received two of the pc680's yesterday. Happy to say they arrive with a 100% charge, 12.84V in one and 12.85 in the other, as stated in their ad. Hope to get them installed in a few days. Please ride 'em safely! Ken krb1945
    Ken krb1945 "Happy Owner"
    USN DAV 100% 'er
    Proud grandfather of a former United States Marine
    1 2008 SM5 PE 548
    1 2008 SM5, 1 2009 SE5
    2008 GL1800
  2. #52
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Marker View Post
    Came across this battery on another forum. It is very small. Not sure how to post a pic from their web site so here is the web site info. ballisticparts.com[IMG]file:///Users/markcrenna/Library/Caches/TemporaryItems/moz-screenshot-2.png[/IMG].
    Since this battery is much smaller than a stock battery maybe extra space could be used for more performance accessories (ie Juice box)
    just an idea.
    [IMG]file:///Users/markcrenna/Library/Caches/TemporaryItems/moz-screenshot-1.png[/IMG][IMG]file:///Users/markcrenna/Library/Caches/TemporaryItems/moz-screenshot.png[/IMG]
    350 Dollars, Is that the price per dozen?
  3. #53
    Alignment Specialist bone crusher's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Lamonster View Post
    I never have liked the stock battery. I think they will cover it up to 6 months but I rather put a good one in it and forget about it.
    Lamont, did you get the SAE terminals and does it work with the battery tender. I know Scotty here said it's wet vs. gel...not sure that matters too much?
    Bone Crusher
    If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
  4. #54
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    Quote Originally Posted by boborgera View Post
    SpyderRT and RS takes a 4 cell battery $135.99. You should not need a dozen of them unless you are powering a lot of lights. Like I said just a thought
  5. #55
    Spyderless Member
    Dec 2008
    north/central n.j.
    Ballistic Batteries just lowered the 12 cell to 189.99, Plus a 3 year warranty
  6. #56
    Apr 2009
    Default Deltran battery tender used on pc680
    Old habits are slow to die... I have always trickled a new battery overnight before installing. So I used the Deltran battery tender on the two pc680s I received and the charge leveled out at 13.3 volts. After sitting in a 40 degree garage with no load for 24 hours they seem to have settled at 13.10 volts. The battery tender seemed to work on these batteries. I do not know if it will work on them if the charge level is at a lower level.
    They came from the dealer with what is a full charge at 12.84 & 12.85 volts. Ken krb1945
    USN DAV 100% 'er
    1 2008 SM5 PE 548
    2008 GL1800
  7. #57
    Registered Users Nino sj's Avatar
    Jan 2012
    Gilroy
    Default Odyssey PC680 Battery
    Got home and the battery on my Spyder was dead again so I went ahead and ordered a battery I know will last a good long time. I've used this battery on my Boss Hoss and I'm sure it will work fine on my Spyder too.
    http://www.batterymart.com/p-odyssey-pc680-battery.html
    Question regarding the Odyssey PC680 Battery, it says that the CCA on them is only 220, isn’t that less than the stock battery which is 350 CCA? The reason I am asking is because I am currently shopping for a battery for my 08 RS and was wondering if you still think it’s a good choice. Thank you so much
  8. #58
    Jan 2010
    usa
    When I look at the specs for this battery it says it is a Dry cell and not a wet cell. Am I looking at something wrong. Yes, I know there is some moisture in a Dry Cell, but it is not the same as a wet cell.
    Willy
    When the going gets tough...Downshift..
  9. #59
    Oct 2009
    ponte vedra beach fl
    Quote Originally Posted by bjt View Post
    Remember the problems many people were having with those original batteries? I thought someone said that the batteries BRP sent with many of the early Spyders were made for upright mounting only per the battery manufacturer and the Spyders battery mount is on its side. A number of owners, my wife and I included, noticed battery acid leaking a bit. Some people got their batteries replaced from BRP but others didn't. Our batteries quit dripping and the dealer didn't do anything for us as far as exchanging them or anything. I would not be surprised that our batteries are a little low on battery acid and probably prone to premature failure. That being said, we haven't had any problems starting our Spyders and its been in the 30s the past few days. We've had our Spyders since March and have over 10,000 miles on each of them.
    i guess i'm lucky i have had my 08 rs for over 4 years and 65k miles. no battery problems at all. i ride it at least 4 times per week and its garage kept.
    it will probably fail tomorrow
  10. #60
    Active Member ameobe's Avatar
    May 2009
    PA
    Thumbs up
    If you go here & sign up for their news letter, they will email you a 10% Priority code used at check out.
    $102.60 free shipping
    Thanks Lamont
    Happy Spyder Owner
  11. #61
    Mar 2011
    SG
    Quote Originally Posted by Nino sj View Post
    I am also shopping for a replacement battery and keen on the Odyssey PC680 as well, but like Nino sj, I am also curious to know the differences in the specs between the OEM Yuasa and the Odyssey battery:
    350 CCA vs 220 CCA
    21 AH vs 16 AH
    I am a noob when it comes to battery.
    Thanks!
  12. #62
Tags for this Thread
