Good scoop on the battery situation. Will run my original battery until she quits. At least I now know where to get a good replacement.
Jack H.
I have purchased and installed the Odyssey pc680 battery and I also purchased the Odyssey Battery charger/tender OMAX-6A-1B.
The instructions and box state that the charger is only for Odyssey 12V batteries only.
My question, " How can the charger really tell if, the battery it is charging/tending, is not a Odyssey brand battery?? ". Not that I would use it on a non-Odyssey Battery...
Alignment Specialist
Lamonster,
Can you start a section on the website that just has parts on it?
For example...one thread might be batteries..and you list the options...make it a closed thread so everyone can't just write stuff in there...you would put on what is validated to work...of course, we'd be your eyes and ears...
We'd have our own Spyderlovers parts section...this is good when we're all out of warranty and/or if we want to upgrade something...
For example, if my battery lasts another 1.5 years and then I need a new one, I certainly won't remember this thread...but if there's a section on parts with a topic of 'batteries', then finding information would be easier....
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
Well, yesterday I started my Spyder - backed out of the garage - turned it off and washed, dryed etc it. Then I went to start it and would only click when I pushed the start button - after a while it said "push mode button" I did and it started - I went for a long ride, stopped a few times - always started right up. This morning I went out and turned the key and the dash lights came on dimly and nothing happens when I push the starter button now.
Do you guys think my battery is out or some other electrical gremlin?? I have it on the charger now and will see if it starts to show more life.....
Can these batteries really be this bad - I only have about 3,000 miles on the bike?!
Mod Maniac
Sounds more like bad/loose connections at the battery.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
its also very cold and snowy here in austria - when i startet my baby - all still ok with the battery (3 month sleeping) but she was smoking/fogging.. 5 minutes - like to much oil or so..
is that normal ?? - she did it never before
chris
Motorbike Professor
The most likely culprits (in no parrticular order) are:
1. Bad battery.
2. Corrosion at battery terminals.
3. Riding at insufficient RPMs for adequate charging voltage.
4. Riding insufficient distance to recharge fully discharged battery.
5. Bad charging magneto (when I grow up I want to be an alternator).
Check or clean terminals, charge it, check charging voltage at sufficient RPM. These things will not charge right at three grand. Battery is warranteed only for six months, as I recall.
-Scotty
Motorbike Professor
chris
Probably a little oil, and a lot of condensation. Won't clear up until the combustion chambers warm. BMW R-bikes are real notorious for this. They will fog whenever parked on the sidestand, or after a long nap even on the centerstand sometimes. They always show condensation for a while when it's cold, usually until the temp gauge shows one bar.
-Scotty
Had same
Mine turned out to be loose battery cables from the factory. Service shop tighten them up and I haven't had an issue since.
Thanks for the replies - I think it is a loose connection somewhere - The charger says the battery is charged - it would not start, then all of a sudden it started right up and went to 2800rpm - I think the battery was disconnected long enough to "unlearn" the computer. I shut it down and started it right back up and now it is back at the 1350-1400 rpm. I am going to track down the cables and see if I can find a loose connection or some corrorsion.
How can you test the battery to see if it is still good?
Mod Maniac
... I think it is a loose connection somewhere - The charger says the battery is charged - it would not start, then all of a sudden it started right up and went to 2800rpm...
That's exactly why I guessed connections. Loose (or corroded) connections at the battery are not out of question for this or any other bike that vibrates a bit. The VTX 1800 was bad about this.
My Spyder:
Mod Maniac
Before you button it up, put some lock washers (star type preferred by me)... or use some red Loc-Tite on those screws!
I found 2 places where I could tighten the screws holding the cables from the battery anywhere form 1/2 to 1 full turn - no corrosion, just alittle loose....maybe?
It is starting fine now -- I am keeping all the panels off and see how it does in the morning - If all is well I will put all back together and take a ride. These electrical issues are the WORST and the most likely to get you stranded.
I am going to carry extra tools for awhile to be prepared.
All "love" relationships require patience and work!..... And this one never asks where I have been....cause I have been with "her"!
My Spyder:
good info thanks alot hope i do not need one to soon
Battery Mart--- How to connect Positive Terminal
Can someone give me a hint on how they installed the pc680 on their Spyder? I can't seem to get the positive terminal connected... the angle of the cable just doesn't want to fit to this battery. Any help/ideas would be appreciated. Thanks
Mod Maniac
I didn't take pics... sorry. But you're right... it is a bugger. If I recall correctly, it just takes a little work to "stretch" the cables to the point of installation.
My Spyder:
I was not able to stretch mine all the way so I went to the local harley dealer and the parts guys gave me an L style bracket that is often used on their bikes. I just replaced mine a few weeks ago and went with a new brand, so I can't share any photos.
RT-S PE#0174
"Happy Spyder Owner"
2010 RTS PE 0174
Custom Plates & paint,
ESI Triple play,mud flap lights,Fender tips/amber,Green Filter,Dayrunner/turn signals,Shortee Antenna,Scuff Guards,LED Brake Lights & 2 in 1 Harness,Brightsides & rear, Glo-ryders/amber, Kewlmetal inside trunk lightz, Garmin 660,Garmin Hood,Volt Meter & Oil Pressure Gauge, Utopia Backrest, IPS Key, ISCI Brake Pedal,Dual side/tall flag poles, SPYDERPOPS Heat Guard
http://www.farriscustoms.com
Originally Posted by Lamonster
That figures. It is a great battery. I've had mine for a while now and it's working great in this cold weather.
well it work for the sm5??????
Senile Member
I just got one. Not as "thick" as the original. But it works great. You might need to shim a little to snug up the battery.
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
You may have a loose connection on the battery. A loose connection will prevent the battery from getting a full charge. Ride 'em safely! Ken krb1945
Ken krb1945 "Happy Owner"
USN DAV 100% 'er
Proud grandfather of a former United States Marine
1 2008 SM5 PE 548
1 2008 SM5, 1 2009 SE5
2008 GL1800
Just ordered 2 pc680's
Current price January 2011 for each is $103.95 and total ground shipping for two is $21.45. I'll be ready to ride when I get back on my feet. Ken krb1945
USN DAV 100% 'er
1 2008 SM5 PE 548
2008 GL1800
Senile Member
Sounds about right. I gotten mine off eBay for $115 with free shipping.
Tags for this Thread
