Looking for Opinions on a Hitch
Hi all, hope everyone had a safe and happy Thanksgiving.
We are in the market for a hitch and thought I would ask what everyone uses and why, be it a BRP or aftermarket.
Thanks for all the replies, Kent.
Ride Safe All
2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
Hitch
BRP
Easy to install
Won't void warranty.
Oh and it's the Best!
BRP hitch also, because of the ease of installation.
Toby
2020 RTL
BRP - easy on & easy off, plus it has a built in mud flap. Watch for a used one.
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
Mike, design us an easily removable hitch! Something that comes off pretty much completely with a pull of a pin or 2.
Many of us would love to have the ability to tow a trailer a handful of times a year, but don't want the ugly ball and bracket back there the other 99% of the time.
PULL PIN ?????
I don't think the hitch is the issue when choosing BRP or something else. It's the wiring harness that's important to me. Since I don't do my own mechanics, I just got the BRP product and moved it from my old RT to my new one. I just hope they don't change it so I can keep using it later.
WELLLLLLLLLLLLLLLLLLLLLLLL!!!
The BRP hitch might be more expensive ...
.. But what is "Peace of Mind"; worth to you?
....Well Bob, you weren't able to attend SPYDERQUEST 2014 so you didn't get to see mine up close and personal.......Had you done so I think you would have agreed with many others there who thought it actually looked better thought out than the OEM one..........One reason being my bolt is SELF - LOCKING at one end .........And even you would agree that the mark-up on all items varies by wide margins ......just because you paid 3 X 's as much doesn't mean it's worth 3 X 's as much ??????.....Mike
BRP WIRING HARNESS
Mike,
You're right; I haven't looked at your hitch...
...That's why I wasn't discussing it.
If you prefer...
When compared to the various aftermarket hitches often seen on EBay...
yada, yada, yada...
Patti's right; the electrical part of the package is probably the most important part of the deal...
.......Well maybe, the wiring H. and the metal Hitch are two separate things ......You don't need use both or actually either .....and I don't " physically " make my wiring Harness .....I buy a commercial 5 wire set-up.....and use an LED tailight that has separate Stop, Running, Turn, signals WITH Back-up lights .....so it's a direct connect to the OEM harness without any converters etc.........................It's the same as if you want a third Brake light , you tap into the Brake circuit with an LED strip........No converter needed.
Mike, Interesting... Wouldn't mind seeing a pic if you'd want to post some.
My initial thought was basically 2 small receivers. Each permanently mounted to either side of the swing arm. Then a U shaped drawbar/ball to connect the two sides???? Just brainstorming a bit...
2 SMALL RECEIVERS ????
...........................Drew, going back to my first reply to you on this ......are what you are calling ...RECEIVERS....what I called ....PLATES.....If they are I see no advantage to permanently mounting them !!!!.........On my HITCH....You take off ONE nut ( plus remove wiring plug ) slide out the BOLT and the ENTIRE thing comes off ...............I can't think of any way this can be easier..................The 14 " Bolt could be drilled for a lock pin But it wouldn't hold the plates tight.....big mistake IMHO Mike
Sorry I didn't respond to anyone, I was out of town on business. Thanks for all the replies and suggestions, I'm thinking of going with the BRP one and only for the warranty issues that may come up. One never knows. The price is a little bit steep thought, but that is my opinion. Have a safe and Merry Christmas everyone, Kent.
Ride Safe All
Just be aware . . .
The use of any other hitch than the BRP one will almost certainly cancel the warranty on certain drive train and suspension components. The manufacturer has stated as much in their sales literature and they have some valid engineering reasons for doing so. In this case the Magnuson-Moss Act does not apply.
[QUOTE=BLUEKNIGHT911;910936]
Originally Posted by Art Mann
The use of any other hitch than the BRP one will almost certainly cancel the warranty on certain drive train and suspension components. The manufacturer has stated as much in their sales literature and they have some valid engineering reasons for doing so. In this case the Magnuson-Moss Act does not apply.[/QUOTE.............. ....Art ....The plain truth here is , this is a SCARE tactic used by BRP and a lot of other manufacturers to get the consumer to BUY their over-priced PARTS.................If what you THINK is true about BRP voiding your Warranty because you use other than a BRP hitch..............Well then this must also be ......85 % of ALL Spyders sold will have their warranties voided because they have but unapproved "FARKLES " on their Spyders......if you believe this ....I have a nice bridge I want to sell you .........I'm not being mean or nasty here , but you need to read the " MAGNUSSON-MOSS " Act a little more closely........Mike
A trailer hitch is not an appearance item nor is it a consumable item. It is a modification to the mechanical properties of the vehicle. The manufacturer puts their requirement in writing on the sales literature. Have you ever been involved as a professional engineer in litigation between a vehicle manufacturer and a vehicle owner who was denied warranty service for questionable modifications? I have. When I say that BRP, or any other manufacturer, has a right to restrict what mechanical or structural changes are made to their vehicles for safety or reliability reasons, I know what I am talking about. This isn't a Magnuson-Moss issue and the hitch is not what I would call a farkle. It is easily (and correctly) classified as a safety and/or structural modification.
It might be possible for an after market company to sell a hitch that matched the mechanical properties of the genuine article. If that happened, then a customer with a broken hitch or suspension might have a legal leg to stand on. From what I have seen so far, the Can Am hitch is unique in that it is unsprung weight on the suspension. I can't figure why they did it that way, but you can bet they didn't just choose that method at random.
I owned Goldwings for many years and frequently pulled a trailer. I did the hitch installation knowing full well that what I was doing could compromise some parts of the new vehicle warranty. Even the hitch manufacturer's installer (Bushtec) admitted that. I actually pulled a trailer and knew that could also compromise certain parts of the warranty. That is just a risk you take when you make unauthorized or (in this case) prohibited mechanical changes or use the vehicle in ways other than what the manufacturer designed it for.
I did take the time to investigate pulling another brand of trailer than Can Am since I own one. The dealer, in fact, said only the BRP trailer is permitted. I noticed that the BRP documentation didn't say anything about trailer brand although they did specify overall and tongue weight. I had the dealer call Can Am technical support right there on the spot and they confirmed what I thought that reasonable substitutes for the Can Am trailer are not prohibited.
NON-FARKLES
happy old fart
[QUOTE=ABQSpyder;908802]BRP
Easy to install
Oh and it's the Best![/QUOT
Regarding whether our warranties would be voided if a non-BRP hitch was installed, I wonder if it's true. In the 2015 parts and accessories catalog, page 101, it states, "Only SYSTEM on the market that maintains vehicle warranty requirements." Similarly, on page 72 of the 2014 BRP catalog it says, "This is the only hitch SYSTEM that maintains your vehicle's warranty." (emphasis added). If an aftermarket hitch mounts the same as BRP's, wouldn't the warranty requirements be met? Anyway, I just had a BRP hitch installed although I don't yet own a trailer. I'm looking into buying one, but it will not be BRP's. They're drastically over-priced and it's not necessary for me to have a trailer that matches my RTS.
WELL.WELL.WELL
[QUOTE=stillriding;911097][QUOTE=ABQSpyder;908802]BRP
Easy to install
Regarding whether our warranties would be voided if a non-BRP hitch was installed, I wonder if it's true. In the 2015 parts and accessories catalog, page 101, it states, "Only SYSTEM on the market that maintains vehicle warranty requirements." Similarly, on page 72 of the 2014 BRP catalog it says, "This is the only hitch SYSTEM that maintains your vehicle's warranty." (emphasis added). If an aftermarket hitch mounts the same as BRP's, wouldn't the warranty requirements be met? Anyway, I just had a BRP hitch installed although I don't yet own a trailer. I'm looking into buying one, but it will not be BRP's. They're drastically over-priced and it's not necessary for me to have a trailer that matches my RTS..................................Well ABQ, I don't want to be the bearer of bad news. Buuuuuuuuut according to Mr. Mann a NONE BRP trailer would also VOID the Warranty..................Personally I think this is B.S. because there are literally Hundreds of different things people have done to and for their Spyders that according to Mr. Mann and BRP has now VOIDED their Warranties......................I don't think any of them care ..........................just sayin.....Mike
