Zumo 660 question
I noticed that my Zumo 660 GPS elevation is incorrect.... is there any way to update/zero/reset it ?
tia
OSM
As far as I know there is not. Following is a quote from the Garmin FAQ section.
How accurate is the GPS elevation reading?
04/14/2014
GPS heights are based on an ellipsoid (a mathematical representation of the earth's shape), while USGS map elevations are based on a vertical datum tied to the geoid (or what is commonly called mean sea level). Basically, they are two different systems, although they have a relationship that has been modeled.
The main source of error has to do with the arrangement of the satellite configurations during fix determinations. The earth blocks out satellites needed to get a good quality vertical measurement. Once the vertical datum is taken into account, the accuracy permitted by geometry considerations remains less than that of horizontal positions. It is not uncommon for satellite heights to be off from map elevations by +/- 400 ft. Use these values with caution when navigating.
I'm not even sure why Garmin puts that in their GPS systems.
as inaccurate as my GSP elevation is.. I am not sure either
OSM
04/14/2014
Plus or minus 400 ft takes us here in Florida from over 350ft under water to over a 100 ft above our highest peak... guess that won't be much good for us...
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
My wife and I both have '12 RT limiteds.
On a trip we have noticed that if my GPS says we are at 2,100 feet hers will read 2,085 or so. Her Garmin is always about 115-120 feet lower than mine.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
Yours must be mounted higher on the bike
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
this posting has been vetted, scrubbed and endorsed by the committee for postings
