What other Upgrades on the 2015 RT Limited
I can only "see" that there are:
A. 2 new color options( Intense RedPearl & Circuit Yellow Metallic), and
B. A different model Zumo GPS.
Does anybody have inside information as to what other changes have been made on the 2015 Limited?
Thanks,
Mike
From what I have read and heard, it is all pretty much cosmetic, not a lot different from 2014, which makes
sense, as they seem to have got it right on the 2014
We now have His and Hers Spyders.
Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
Previous Spyders
2013 ST SM5
2011 RSS
2010 RS
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Originally Posted by akspyderman
Come spring, I see an "upgrade" coming. I have missed my "automatic" trunk.
Are you aware that you can open the frunk with the engine running. With the engine on, simply depress the key and then turn it to open the frunk.
You can also open up the seat with the engine running using the same procedure.
IBA #47122
2020 RT Limited Asphalt Grey
I also got soft and lazy with my 2010; this switch is going to added to mine, for sure!
None Its colors only,power front opener that's it..
Originally Posted by PW2013STL
I agree turning the key to open the frunk is so much more work than pushing a button. What was BRP thinking
You know, I was just thinking the same thing. If BRP were really classy, they would have a remote key fob lock/release like the Goldwings do. I remember using it at least twice during the 10 years I owned the bike.
that's right. Most of the time I would forget to hit the button before turning off the switch and would have to push and turn the key anyway on my 2010 RTS. I really don't miss it at all on the '14 as you can open it with the Spyder running anyway. Some folks want it and that is fine but I have found that it is not needed.
Happy Spyderlovers
Hopefully they've added Bluetooth to the audio system, they are way behind the times with still having to plug in your iPhone/iPod in the trunk, with an outdated cable at that, maybe they've at least went to the Lightning cable to plug in a iPhone 5/5s/6. How about power on the dash for all models, that would be great.
