Tow Dolly
I was wanting opinions about using a dolly like you tow cars with to pull a Spyder. I have little use for a trailer and even less room to store it. I thought about getting a dolly for times when I needed to haul my Spyder . The two main reasons is, it wouldn't take much room to store it and it would be easy to load and secure the Spyder. I would appreciate your thoughts.
I have been wondering if there was anyone else having those thoughts. It seems like it should work, but normally cars are strapped down over the tires. I don't see there being enough room between the fender and tire on a spyder to do this. If a good tie down can be established, it should work.
Tow Dollys put the drive wheels off the road. It MIGHT be possible if you pulled the belt, but then you have to reinstall the belt, including setting the tension, belt alignment, and if you have had a laser alignment, once you do all that your alignment will most likely be off. We pull a car on a tow dolly behind our RV, no way I would consider doing it with the Spyder.
Clifford Fargason
2013 Spyder RTL
2007 Royal Star Venture
Agree..!!
had though about it a lot but came to the same conclusion. Kendon makes folding trailers that stand up against the wall saving space. Just have to see if they have one that fits your needs.. Just checked and they do....
2012 RS sm5
That was my first thought as well.
Originally Posted by Gray Ghost
Tow Dollys put the drive wheels off the road..
We have used a tow dolly with the drive wheels on the ground for short distances. But I agree, I wouldn't want to pull a car or spyder very far like that.
Thank's I wasn't really concerned about pulling the Spyder because over the years if towed several cars. But I was concerned about the transmission. I didn't know if the trans was fully disengaged when it was in neutral. So by your answers it appears it's not so I guess I will check on renting a trailer when I need one. Thank's again for your help.
Just thinking...
how 'bout a dolly where the REAR wheel/tire is raised off the ground?!
You would lock the steering with some sort of straps, and the Spyder would be pulled backwards down the road.
Please, beat me up. Just thinking " out of the box"
Bill
Bill
Nothing wrong with being outside the box! However, the problem with this set-up is that the front-end of the Spyder would probably drag with the rear wheel raised up on the dolly.
Going to be a difficult thing to pull off.
I'd never try to tow it with the rear wheel on the ground. Your asking for mechanical problems there.
Towing it backwards is for sure going to present some nose clearance challenges as well.
If your going to be very limited on your trailer use your probably better off looking for a rental place or finding another local SL that may be willing to loan you theirs and working something out with another local rider.
Where are you located?
Get a fabricator to build you a 3 wheel trailer that stands up when not in use. It would match your spider and look cool!
JT
OK then...
Out of the box is good!
But dragging a Spyder backward... not so much
The windshields would take an awful lot of strain that they're not designed for.
All good points,
I'll shut up now
Bill
...and with the issues of the windshield bracket and the clearance in the front with that angle not workable.
By pulling the belt by removing the shock bolt you could free wheel the rear tire and the ratchet straps could go over the lower control arms instead of the tires. If I were going to do it, that would be the way to go. The rear bearings would have very little weight on them with no rider. I think it is do-able.
The owners manual says to NOT even trailer with the spyder facing to the rear.
We pull a car 4-wheels down. I'd LOVE to figure out a practical way to take the Spyder along as well. Putting it on a lift between the MH and the car would make for for a very long rig - not to mention the cost of such a lift.
It would work .
I saw a Trike begging towed at Bike Week in Fl. I have seen a Smart cars on a tow dolly. The only down side is the rear tire ware.
Mike
There ARE other options...
I have a "Drop Tail" trailer for use in hauling the Spyder. It will fold to about 5 ft tall and 18 inches or so in depth.
Dream set up for people with money(does not includ me). A pick up truck with the factory bed off and a flat bed installed, towed behind a motor home. Spyder on the flat bed.
Oldmanzues
Its not 4 down but this is what we are looking at to pull behind our class a
http://www.cruiserlift.com/towdolly.html
Sent from my SCH-I545 using Tapatalk
YEP I DID THIS
