Results 1 to 8 of 8
    Oct 2007
    Default Towing a Spyder - Best way?
    I'm wanting to tow my Spyder RT behind my Ford SUV. I also want to put the trailer in my garage, so the height needs to be less than 82" (6 ft 8 in).
    thanks.
    What kind of trailer do you have?
    (by the way...82", is 6'10"...)
    Active Member SAR41's Avatar
    Sep 2014
    USA, Wyoming, Evanston
    Default Rampage Motorcycle Lift
    I decided to go with the Rampage lift http://rampagelift.com/Cont.html
    I just installed it last weekend. Works great. I went this way so I can put it in the rear of my pickup and then we tow the pickup behind our motorhome. All you have to do is back up the bike to the lift, strap the rear tire into the shoe and then use the remote winch control and it puts the bike in the back of the truck. It goes in backwards so you need to remove the windshield first but that easy, 6 screws and it's off.
    Then if you want to remove the lift from the truck all you have to do is remove 4 bolts and it can be taken out of the truck. It weighs about 300 lbs so you will need a hoist or a fork lift. Or you can take it apart into three pieces and one person and remove it.
    Just another option.
    2014 RT Limited, #0085 Silver Platinum Satin with Black Seat
    Spyderpops Bump Skid Plate, Belt Guard, IPS, SS Knott Grilles,
    Show Chrome Luggage Rack, Passenger Arm Rest, 3 pc Lid Net Set,
    Smart Mount Driver Backrest, Windshield Dash Pouch System,
    TRICLED Blinkers and Brake Lights.
    Too Many Toys and Not Enough Time!!
    Default Gotta say..!!
    there is no best way to tow a spyder...ryde it... best would be an open trailer and if narrow you will have to put her on backwards and remove the windshield...
    ​2012 RS sm5
    It's much better to ride them, than it is to drag them!
    Active Member RyderJCF's Avatar
    May 2013
    Ocoee, fl
    I use a triple crown utility trailer, 6x12, which fits easily in the garage. A 6x10 works but the extra 2 feet was only 30 bucks!
    ​Jeff
    2012 RT Limited Lava Bronze (aka "The Bronze Beauty")
    Ultimate faux crocodile seat, backrest , and armrests in cognac-/black, Luggage nets, luggage, drink holders, top mirror, shorty antenna, SENA SMH10 headsets and SMR10 dongle, Garmin 665lm, Tri-pouch, Trunk mount flag poles, Custom Dynamics vent covers, Show Crome Luggage Rack, custom mud flap, Full Size Brake Pedal, Tricled mirror turn signals, LED strips on rear of front fenders, custom highway pegs, BakerBuilt Air Wings w/ Uppers
    2012 RT Limited , Lava Bronze
    Mar 2013
    Maumelle, AR
    Default I used to own a Droptail Trailer...
    These work great and then store out of the way in your garage. Check them out.
    http://www.droptailtrailers.com/shop...e-trailer.html
    2020 RT Limited , Chalk
    Very Active Member Buggy's Avatar
    Ontario Canada
    The Ulitmate trailer can be lowered to the floor inside the garage and then the Spyder parked on it.....saves space.
    2016 RT Ltd. , Pearl White
Tags for this Thread
