Ignition tumblers
Are sticking and not allowing the key to go down far enough to work. Can keep fooling with it and it will finally work. Also sprayed it with quick dry electronic cleaner and it freed up the tumblers. Was wondering if there is a lubricant that I can use to keep them from sticking?
Graphite, available at Home Depot or Lowes in their key making area. One little squirt annually.
OK thank you for the insight, will give,it a try.
Try this..!!
WD-40 works well too...
2012 RS sm5
