Results 1 to 25 of 26
    Sep 2014
    Land O Lakes FL
    Default Stock tires will not track straight
    My 2014 RT limited was pulling to the right so I had it laser aligned but that did not solve the problem. I am using exactly 20 psi in both front tires. Mike Loescher (the inventor or the laser alignment system) suggested that I try switching the front tires. I did this and found that now the bike pulled to the left. Mike said that Can Am has had a problem with many of the stock tires on the 2014 RT Limited bikes. I replaced the tires back to their correct position and then informed my dealer (Tampa Bay Power Sports) about this problem. I am waiting to see if they are going to replace the tires. Has anyone else had similar problem?
    Registered Users Vossr's Avatar
    Sep 2014
    San Antonio, Texas
    Default Pulls to the Right
    My 2014 RT-L does pull to the right if I pull back from the handles for a moment. I haven't had the chance to get a laser alignment done yet. Hoping to wait til between 2000 & 2500 miles, see if it 'breaks in'. Though, we know how those types of hopes n wishes work.
    Vossr
    Sage Monkey
    MSgt, USAF ret
    Default Bummer..!!
    there are threads out there about tire problems on tge 14's. Both rear wear due to compound change now changed back and faulty front tires. Don't know wgats being done about that...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member donnellpj's Avatar
    Sykesville, MD
    Default Tire woes
    I can't say I have noticed the Spyder pulling in one direction over the other.
    What I do notice is, after a long-ish ride, while the tires are still warm, I park it in my garage and both fronts develop flat spots.
    The flat spots seem to subside after ~30 mins into the next ride, but I find it odd that they do that in the first place.
    The initial wallop and shimmy is annoying.
    2014 Spyder RT Limited , OEM NA Satin Platinum
    RE: the bad tires in the OP.
    Dealer should replace the bad tires under warranty. The test of changing out the tires from left to right and the doing the opposite dance should indicate a problem with the tires.
    Also, the fact that a laser alignment did not help, is another argument in your favor.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by donnellpj View Post
    Kind of like the old nylon cord tires on cars and trucks.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    I had a problem with my tires. One of them was not "true" My dealer replaced it under warranty. They said they had seen a few issues like that.
    2014 RTSS , Cogna/ black
    Registered Users SllimG's Avatar
    Weatherford, Texas
    Quote Originally Posted by Richard Brown View Post
    Exact same problem. Did the laser alignment and it still pulls to the right. My RS tracks straight and true but with the 2014 RT I can't take my hands off for a second.
    Very Active Member granpa in Cincy's Avatar
    Oct 2010
    Cincinnati Ohio
    I had that exact same problem and both tires were replaced under warranty.
    2014 RT S SE6 Cognac. Built on 12/20/13.
    2014 VW EOS 2.0 TSI replaced the RT S 5/22/2017
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    My 2014 RT does pull to the right also... I was thinking about getting the laser alignment... now I am not sure...
    Registered Users Gray Ghost's Avatar
    Harper, Texas
    Quote Originally Posted by Orange Spyder Man View Post
    Only a very small percentage of Spyders have been found to be in good alignment from the dealers. All the independent ROLO dealers I know of will check your alignment for free, cost only comes in should you need an alignment. You may have bad tires, but I'll bet an ice cream cone that you also have alignment issues.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
    Bossier LoUiSiAna
    No expert here but my share of old vehicles & bad roads, most everything pulls right, not from alignment but just the grade of road to drain rain water off,fyi. I've goon to using dynabeads on most all my vehicles & has helped. G'luck with what you got & choose to do[emoji106]
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    Quote Originally Posted by granpa in Cincy View Post
    Likewise.....
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Jun 2010
    Las Vegas
    We have aligned three Spyders that have had the same issue and each of them were able to get their tires replaced under warranty. If your Tampa dealer won't work with you try Central Florida Powersports.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2014
    Land O Lakes FL
    Yes all my vehicles do seem to follow the crown but my spyder is pulling to the right so hard that it will climb right up a crown and when I switched the front tires it pulled to the left even when the slope of the road was to the right. This is after a laser alignment. Seems like a bad tire to me.
    Jun 2010
    Las Vegas
    You probably have a bad belt in the tire. The symptoms you cite are the same as others who have had a bad belt. This should be replaced under warranty.
    2010 RT- 622
    Sep 2014
    Land O Lakes FL
    Default New tires fixed the problem
    Tampa Bay Power Sports replaced both front tires, now my Spyder tracks perfectly.
    Thank you for posting about the fix. Many times we do not get the "rest of the story."
    Invalid Emails
    Laurel Hill Fl
    Default Pulling to the Right hard
    2014 RT L Mine is pulling hard to the right also. Dealer has replaced three sets of tires so I am on the 4th set of tires. I have had a laser alignment done it did get rid of most of the shimmy in the front end but it still pulls to the right. let go of the handle bar and it pulls to the right 1/2" hard. the only way that it will go down the road straight is if you put the tires on backwards (*reverse rotation) it will go down the road for over a 1/10 mile with no hands at all! Is there any thing that will help but a new set of tires?
    Bryant, Arkansas
    I would suggest that you try a different set of wheels and rims. Maybe your dealer would let you try a set off of one of his.
    Cruzr Joe
    Invalid Emails
    Laurel Hill Fl
    Cruzr Joe
    They did try a new set of rims and tires same result they came off a new 2014 RT L
    Nov 2012
    North Las Vegas, NV
    Still sounds like bad tires.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Active Member zbunker's Avatar
    Dec 2011
    Altamonte Spgs, FL
    Default Pulling
    Quote Originally Posted by PRDodds59 View Post
    I'm in the same boat. Everything is like it's supposed to, (including reset sensors) yet I still drift to the right.v
    Mar 2013
    Marion, Arkansas
    I have the exact same problem. The tires will develop a flat spot and when I take off the whole front end and windsheld will shimmy for about 15 minutes and then settle out. I thought the first time it happened that my windsheld was going to fly off.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Dec 2014
    Lee's Summit, MO
    Had the same thing. Dealer put on new tires at 400 miles under warranty. Old tires had an unbelievable amount of weights. One side had 15 and the other side had 8.
