Page 1 of 14 1234511 ... LastLast
Results 1 to 25 of 331
    Jun 2013
    NE South Carolina
    Default NHTSA investigation update
    Here is a NHTSA PDF dated 10/16 asking BRP to provide EVERTHING ever reported about the heat and fuel smell issues. Sounds like they have an idea what they want to see it is very detailed and specific. It is 14 pages long so be prepared to do a little reading. It seems they are concentrating on the EVAP overflow, excess heat (boiling gas) and MC and asked if pre 2014 owners will get the 2014 body panels (RT's) plus a whole lot more. They want to know what BRP knew about any of this and when they knew it. BRP must reply by Dec 5 and they mean business in closing they said
    "BRP's failure to respond promptly and fully to this letter could subject BRP to civil penalties
    pursuant to 49 U.S.C. § 30165 or lead to an action for injunctive relief pursuant to 49 U.S.C. §
    30163. (Other remedies and sanctions are available as well.) The Vehicle Safety Act, as
    amended, 49 U.S.C. § 30165(a), provides for civil penalties of up to $7,000 per day, with a
    maximum of $17,350,000 for a related series of violations, for failing or refusing to perform an
    act required under 49 U.S.C. § 30166.
    See 49 CFR 578.6 (as amended by 77 Fed. Reg. 70710
    (November 27, 2012)). This includes failing to respond completely to ODI information requests.
    If BRP cannot respond to any specific request or subpart(s) thereof, please state the reason why it
    is unable to do so. If on the basis of attorney-client, attorney work product, or other privilege,
    BRP does not submit one or more requested documents or items of information in response to
    this information request, BRP must provide a privilege log identifying each document or item
    withheld, and stating the date, subject or title, the name and position of the person(s) from, and
    the person(s) to whom it was sent, and the name and position of any other recipient (to include
    all carbon copies or blind carbon copies), the nature of that information or material, and the basis
    for the claim of privilege and why that privilege applies.
    http://www-odi.nhtsa.dot.gov/acms/cs...4025-60435.pdf
    Nov 2013
    Oro Valley Arizona
    How about that. Can not wait to see what happens.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Aug 2013
    Well one thing about BRP...they don't do anything fast...guessing they're gonna be paying fines...be prepared to pay more for your next Spyder. Personally, I won't be buying another...
    Mar 2010
    SD
    If BRP didn't know, their R&D is severely lacking. If they did know... well, you know! Profit at all cost, I guess! We shall see.
    Jun 2013
    NE South Carolina
    Here is a taste of the letter concerning the RT's
    13. For all MY 2010 through 2015 Spyder RT models (including all trim variants), fully describe
    all assessments, analyses, tests, test results, studies, surveys, simulations, investigations,
    inquiries and/or evaluations (collectively, "actions") wherein temperature readings were
    noted, for any reason, for any of the following areas: fuel tank exterior surface(s); fuel in the
    tank; vapor emissions canister exterior surface; brake master cylinder; and/or any exterior
    surface of the motorcycle body. Provide a spreadsheet listing each action and, then, for each
    "area," the maximum temperature(s) noted.
    ·14. Fully describe all assessments, analyses, tests, test results, studies, surveys, simulations,
    investigations, inquiries and/or evaluations (collectively, "actions") wherein temperature
    readings were noted that support BRP' s marketing claim of "improved heat management"
    found at http:!/can-am.brp.corn/spyder/shopping-tools/why-choose-can-am-spyder/the-new-
    2014-spyder-rt.html for the MY2014 Spyder RT models. Provide all documents
    comparing/contrasting the temperature readings BRP relied upon when making that claim.
    15. For all MY 2008 through 2015 Spyder "sport" models, fully describe all assessments,
    analyses, tests, test results, studies, surveys, simulations, investigations, inquiries and/or
    evaluations (collectively, "actions") wherein temperature readings were noted, for any
    reason, for any of the following areas: fuel tank exterior surface(s); fuel in the tank; vapor
    emissions canister exterior surface; brake master cylinder; and/or any exterior surface of the
    motorcycle body. Provide a spreadsheet listing each action and, then, for each "area," the
    maximum temperature(s) noted.)
    Oct 2014
    Deep South
    Sounds to me like they are about to force a recall on BRP. I am surprised that BRP hasn't done so voluntarily considering the number of people who have reported fuel problems and the potential liability.
    Houston
    Reading between the lines, its obvious there have been some prior correspondence on the subjects. Of interest is that BRP has reported to NHTSA that other makes and models of motorcycles emit fuel vapors when parked rather than storing them in the canister. NHTSA in essence says, really? who? We need to talk to them as well. Oh, and we want to see those CARB test reports where this vapor belching system supposedly passed emissions testing.... You can bet the EPA and CARB are watching this closely as well.
    It will drag out a while. Also what's up with the 2015 RT body panels, is there something new on the 2015 RT that we missed? Or is NHTSA a year off on its request. Personally I would be very happy if BRP was required to refit all 2014 body panels and the associated heat management parts to my 2013....Would go a long way to solve the problem. Still have exhaust routing problems but....
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Houston
    Quote Originally Posted by Art Mann View Post
    I think the recall is a forgone conclusion. What is going to be argued is how much will be required.
    Jun 2013
    NE South Carolina
    I see NHTSA's site is down again , been pretty busy there lately, so here is a link for anyone that wants to read the PDF
    https://drive.google.com/file/d/0B7P...ew?usp=sharing
    Jun 2013
    NE South Carolina
    I read a member here is a test mule for BRP on a 2013 with a reversing fan under 6mph. That may help with the black hole heat at stop but does nothing for the rest of the issues with the EVAP system and boiling gas. I am not sure maybe a 2014 owner can tell us if the 2014 front triangles are engine vents or not. You know the ones above the radiator holes. I am thinking NHTSA simply means the 2014/15 body panels on the RT.
    Thinks out loud
    Apr 2012
    Thumbs up Interesting
    Sounds like the band aid has FINALLY fallen off.
    Thanks for the update.
    Thinks out loud
    Apr 2012
    Arrow Months ago
    Quote Originally Posted by Magdave View Post
    ● a reversing fan ● under 6mph. That may help with the black hole heat at stop but does nothing for the rest of the issues with the EVAP system and boiling gas. I am not sure maybe a 2014 owner can tell us if the 2014 front triangles are engine vents or not. You know the ones above the radiator holes. I am thinking NHTSA simply means the 2014/15 body panels on the RT.
    Months ago I communicated with BRP about the possibility of them offering this. At our expense/or not. Need I say....they never responded?
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Well I as well as many other RT owners will be standing by to hear of the doc's submitted by BRP.
    I think this could of gone 2 ways. BRP could of known of the heat issues from customers and never did there own R&D to support or deny the claims. Or know of the issue and wait for the NHTSB to come up with their evaluation hoping for a lesser of the 2 evils. But it might be to late for BRP? Would be curious to see the actual documents provided by BRP. I would be betting that they will not be nearly a bad as myself or others have claimed about the heat issue, boiling gas, or fuel smells.
    Guess we'll just wait and see.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Jun 2013
    NE South Carolina
    Quote Originally Posted by M109Dreamer View Post
    I and several others have submitted temp readings(with pictures) To both BRP and Bob Young the NHTSA investigator. so they can run but they can't hide. There are plenty of measurements others here have posted too and you know NHTSA has been pouring over the posts. They even include a screen shot of one of the posts here in the PDF. I and others have also posted pictures of the gas dripping from the EVAP hose. This whole mess includes ALL Spyders too not just 2013's. Hopefully there is light at the end of the tunnel. I am guessing Jan or Feb will be the conclusion of the investigation. If you have fuel smells after a ride it is last chance to file a complaint
    Mar 2011
    Jackson, MS
    I and several others have submitted temp readings(with pictures) To both BRP and Bob Young the NHTSA investigator. so they can run but they can't hide. There are plenty of measurements others here have posted too and you know NHTSA has been pouring over the posts. They even include a screen shot of one of the posts here in the PDF. I and others have also posted pictures of the gas dripping from the EVAP hose. This whole mess includes ALL Spyders too not just 2013's. Hopefully there is light at the end of the tunnel. I am guessing Jan or Feb will be the conclusion of the investigation. If you have fuel smells after a ride it is last chance to file a complaint[emoji106]
    I hope too. We havent had issues with the gas dripping but the heat has literally left burns on the inside of my wifes legs. And the fumes have been there from day one. Like everyone else, we were told "they all are like that". Well a few more months and maybe we will find out what all comes out in this.
    Ours is a 11 RTS
    Active Member Raknid's Avatar
    Central NJ
    I still get the fuel smells after a long ride or hot day. Is there still a need for more customer information? Sounds like investigation is underway..
    2012 RT-SE5
    Jun 2010
    Las Vegas
    Wouldn't it suck to be an employee at BRP working on these responses?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    SoFlo
    Oh Boy...
    Hope this all works out for Owners, BRP and the Gov't.
    Something needed to be done.
    All the best to those affected or involved.
    PK
    Very Active Member mastertek2000's Avatar
    Mar 2012
    E Freetown MA
    This is great news they have to step up now what really get me is all the dealers from what i read when you ask them if this is a common problem they all say the same thing i never heard of this before yup OK lets hope justice will be served i am about ready to trade my 2013 because of the fuel smell been to the dealer 2 times on more time then i will file a lemon law this surelly will help anyone that wants file a lemon law on their bike
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Seems like BRP rolled the dice and it's coming up snake eyes. Between the fires and gas fumes/heat, this isn't something that NHSTA could look the other way or sweep under the carpet. By the tone of the response, it appears BRP hasn't been very responsive to them either. Bottom line is, I hope everyone who needs a remedy gets one and that BRP's damage isn't to the point where the spyder would be in jeopardy (i highly doubt that). One would have to hope they will learn a lesson here and listen to all us beta testers.
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Thinks out loud
    Apr 2012
    Arrow When the fan boys go silent
    Crickets.....
    After having read through the information request. One thought came to mind. This is far from over. It's just getting started. Sad thing is....it DID NOT have to come to this. 'Choices' do have consequences.
    Dave,
    Thanks for the update!
    There's going to be repercussions to all of this...
    I guess that we'll have to wait and see where the chips fall...
    Thinks out loud
    Apr 2012
    Unhappy Remember
    When I think of all the 'Good Folks' over the years who have been attacked for complaining about everything that is now under investigation. In truth. It makes me sick.
    Jun 2013
    NE South Carolina
    I, for one < am hoping this is a case of patience (and being stubborn) will be a virtue in this case. Did you notice the recall compliance numbers? ~75% have had it done I wonder about the other 25% and how many potential melted MC and Evap canisters are ready to pop? That is the scariest part. Maybe some were trade ins
    May 2013
    Stanton, ca
    Bottom line I can recreate the fuel smell issue easily!
    1) Have about 1/3 of your gas tank full.
    2) Ride in stop and go traffic in 90F or above ambient temps for about 30 minutes.
    Every time I have this combination the gas stink even while on the thing is pretty bad and there have been days I almost had to get off the thing as it was making me nauseous.
    However, I have been doing what others suggested. Fill up the tank before going home.
    YES when I pop the cap off the gas is boiling so much you can hear it just standing next to it.
    But filling it up does calm down the issue so I can park in the garage without my wife freaking out but I have to ride it a few miles to let the evap can clear.
    Still some gas smell but certainly not as bad as had I not filled it up.
    As far as heat, either I am tolerant or not having an issue.
    Yes with my NVB pegs the blow hole will burn you so it has to be blocked off to use those.
    But on the stock pegs, I only have a little discomfort and can feel the heat but not enough to make me stop riding it.
    But, this is good news for us users. I will take any fix that solves the stink and the fumes which is a fire danger in my opinion. I have been grounding myself to the frame before opening the gas cap and other precautions to not ignite the fumes!
    Lets all hope for a quick resolution to this
    Bob
