Results 1 to 25 of 32
    Mar 2010
    Indianapolis, IN
    Question Bajaron's sway bar billet end links.
    I own a 2012 RT-S that has Bajaron's sway bar installed with the stock end links. Was wondering if the '12 had any problems with the stock end links breaking or cracking that would warrant replacing the stock links with the billet links?
    Just to be on the safe side; I'd replace them.
    My reasoning: the stiffer Anti-SwayBar is putting more a load on the those plastic oem links...
    Mar 2012
    NJ
    No issues with the stock 12' links. However, with the weight of the RT and the stiffer bar, I'd swap out the stock links if I rode an RT.
    Nov 2012
    North Las Vegas, NV
    They weren't available when I got the sway bar. So far so good, but I may upgrade in the near future.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2013
    Delaware
    I'm sure the old links will work for ya but the new ones are not that much and very easy to change. And remember with links worst case if one breaks it doesn't break on a straight shot it breaks on a turn under load and if your not ready for that could be a bad scene.
    Mar 2012
    NJ
    Quote Originally Posted by billrob71 View Post
    So your saying worst case is I'll crash?....thanks...
    Next time you get left behind the camery on the ride home!...[emoji12]
    Jun 2013
    Cleveland,OH
    I'd replace the links.
    Jun 2013
    Delaware
    Quote Originally Posted by DrewNJ View Post
    Well thats just great I got GPS I'd get home eventually
    DAM CARS
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    DAM CARS
    <Not following bill anymore It's one thing getting lost, it's another thing getting lost when its time to eat!!
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Quote Originally Posted by spyder3 View Post
    Mar 2012
    NJ
    You know how those Delaware people are......
    Jun 2013
    Delaware
    Alright not waiting anymore for you
    Jun 2013
    Delaware
    Nice
    were is my cane at ,someone needs to a adjusted
    Mar 2012
    NJ
    Nice
    were is my cane at someone needs to a adjustment
    Say what[emoji845]
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    Look at the new link vs the old and you will see the difference. Replacement then becomes a no brainer.
    Mar 2010
    Indianapolis, IN
    Thumbs up Thanks for all your replies!
    Sounds like the consensus may be better safe than sorry. As the cost is not that great I guess I will consider replacing the stock links.
    You'll be glad that you did!
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    I figured that a beefier bar, warranted beefier links! Glad I did!
    2012 RT , stock Lava Bronze
    Sep 2014
    Los Angeles
    On the RSS. Do you need to remove Baja Ron's bar to remove factory links to install new links? After reading everyone's post I guess the smart thing to have done was to replace while I had everything down. RSS has less than 2500 miles and it is not ridden by an aggressive rider.
    Quote Originally Posted by GunDoctor View Post
    You don't need to remove anything to swap out the Heim Joint Links. Just lift the front of your Spyder enough to slide under it. Using 2 13mm wrenches (ratchet, open end, box end, they all work), take 1 bolt off the top link connection. 1 bolt off the bottom link connection. Replace with the new link, replace the 2 bolts and tighten. Do the same for the other side and that's it.
    Oh! Forgot to say that you do need to let the jack down. Very important step!
    Default As I see it..!!
    for the price and ease to change them, why not eliminate the doubt.
    Sep 2014
    Los Angeles
    Thanks Ron, especially the jack part, and will assume I slide out first.
    You know... You're RIGHT! There are probably some Spyderlovers trapped under their machine right now! I am SO Sorry for leaving yet another important step out of the sequence!
    My Bad!
    Active Member Dgjason's Avatar
    Old River Winfree Texas
    That's ok Ron, you were too busy answering my PM...lol
    2013 ST Limited
    Sep 2014
    Los Angeles
    Default Bajaron's sway bar billet end links.
    Received my new fancy red links today...fast service, thank you Ron. Will give me peace of mind knowing I won't have to worry that the new sway bar will cause an issue with the stock plastic ones on my girlfriend's RSS
