Results 1 to 13 of 13
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Thumbs up I got my Spyder back!
    Update! BRP must of read my thread. My Service Advisor Kevin Smith at Performance Power Sports in Seneca, SC. really did a great job for me. When BRP was having the tech. Joshua Phillips doing testing on the first replacement part from BRP. Kevin stopped the testing and told BRP to send a new part ASAP. They received the new late Monday, Kevin called me Tuesday, everything new part was working and I went to get it and drove it home, and it ran great. I'm HAPPY! HAPPY! HAPPY! After I come back from the Smoky Mountain Spyder Rally this weekend I'm going to have Performance Power Sports in Seneca, SC. do the front tire rotation and a Laser Alignment. I found a good dealer finely.
    Mike
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    glad they got you up and running so quickly
    Default Great news..!
    skip the tire rotation but get the alignment that is worth it. They may be doing them at the event...
    ​2012 RS sm5
    Active Member rays hell's Avatar
    Hiram Ga.
    Great to hear,Mike. Hope to see you in Fontana.
    Jun 2010
    Las Vegas
    I agree with Chupaca, skip the tire rotation but definitely get an alignment.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2011
    Mount Airy,Ga.
    The tire rotation helps extend the tire life from 25% to 40%. I kept track of the ones that did rotate to the ones that didn't.
    Mike
    Default ROTATION
    Quote Originally Posted by SpyderAnn01 View Post
    ...........If your tires are not wearing Evenly there is a Problem.......You really need to fix the Problem......Not put a Bandaid on it.....Because if you Rotate your now , you will have to rotate every set you ever buy for that Spyder...............If you get your Spyder Lazar aligned you will get much better milage from your tires , and the Spyder will Handle better.........................Rotating tires is not cheap, and has the potential of Damaging the Rim every time you have it done...........This is not just my opinion but the opinion of EXPERTS ....................Mike
    Feb 2013
    UK
    Cool
    Good to hear you got your bike back....Tyre rotation v. Ann's great alignment service?
    Get BOTH!!
    Glad to hear you are back on the road.
    Jul 2011
    Mount Airy,Ga.
    Mike,
    When I changed the BajaRon anti-sway bar and the 2012 RT shocks it gave me a little negative camber in the turns, measured it(before & after). So they wear more on the inside of the front tire and I have 10,000 miles on the tires after changes. I know a stock 2011 RS-S with stock setup wear evenly. I take measure the tread every 5,000 miles. If your like me and run a lot twisty roads you should grease your frontend every 3,000 miles, otherwise every 6,000 miles. I use Amsoil grease. I'm going to upgrade when my extend warranty in 2016 runs out, if the 2016 ST has the ACE engine. That's IMHO.
    Mike
    Default BUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUT
    Quote Originally Posted by MikeinGA View Post
    Mike,
    Mike
    ......Mike I'm not a suspension expert ( )....But there are no Camber adjustments on / for the Spyders......So I don't think they can actually get out of adjustment...( unless suspension is damaged )......IMHO if you have wear issues ...it's related to ....TOE-in or TOE- out.......Maybe PMK can help out on this one or Ron.........Mike
    Jul 2011
    Mount Airy,Ga.
    Mike
    When I changed my RS-S shocks that were at position 5 on the spring setting to 2012 RT shocks at position 2 on the spring setting and when we ride 2 up the Spyder is lower causing the negative camber and little less caster (very little). Due to the negative camber I get a little less tire roll over and better handling in the twists. I had a vintage 1963 Austin Healy Sprite and that had no caster or camber adjustments. To adjust the camber I modified the upper shock arm bushing with an off set bushing and I needed to change the caster I would raise or lower the rear of the car I would change the coil over springs. I have no suspension damage. The manual tells you to rotate the tires when the is at 4mm.
    Mike
    Oct 2014
    Georgia
    Mike, will the dealer in Seneca do an alignment "while you wait," with an appointment ?
    Don't want to get stuck out of town, with no return ride home, if the can't / won't do the work when scheduled. Don't mind the 2+ hour ride up, and another to come home...nor sitting on my butt for an hour or two waiting for the alignment to be done. Just want a good reference for a dealer, as to timeliness completion of scheduled appointments...
    Regardless of the Avatar...call me "kliff," please Formerly VRCC # 1761
    2012 Neutron Green RS-S
