My Bajaron swaybar installation
Howdy,
I have a 2014 RT LTD and decided to get the Bajaron sway bar. Ordered it from Lamonster (Twice now I have placed an order late Friday night US Central, he shipped out on Saturday and I had the item on Monday/Tuesday)
Anyway so I decided to use my pickup truck loading ramps to get the front of the Spyder up high enough to remove and replace the swaybar.
Some of the things I found out when trying to use the ramps with the Spyder.
1. The electronic parking brake, when engaged with the bike on the ramps, DOES NOT have enough grippage to prevent the bike from rolling back down the ramps.
2. Tried to get the bike up on the ramps, leave it in gear, engage the parking brake and turn off the engine. No joy. Bike still would roll back down the ramps.
3. Wheel chocks did keep the bike in place but then its a two person job, rider stays on the brake while the chocks are put into place. Oh and don't use cheap plastic ones. The will crush after a few minutes. Get solid rubber ones.
What I wound up doing is all the work of removing panels, nuts and bolts while the bike was level in the driveway. When the sway bar was ready to come out, that is when I drove her up the ramps while a friend placed the chocks and removed/replaced the sway bar. I stayed on the bike and the brake during this time (maybe 1 minute).
After the new bar was in place, rolled her off the ramps and put everything back together. At no time during my installation did I have to actually get under the bike.
Took a quick ride around the neighborhood and was impressed at the change. In a tight, quick circle I didn't feel like I was going to be thrown from the bull.
Enjoy and thanks for your time in reading my little story.
--Allen
Nicely done..!!
park brake may need some adjusting..still need to block it anyway. New method..never heard of the ramp and truck but great way to get the hight needed. Congrats..!!
Didn't know you really needed to remove any of the tupperware to install the sway bar... I'll put mine up on HD jack stands for the install
Yeap. I can only speak to the installation on a 2014 RT. I followed the directions which call for removing 3 pieces of tupperware on each side of the bike.
Even up on jack stands you will still need to remove those 3 pieces. One of the pieces actually extends down to around the bend in the sway bar. If you don't remove that piece then you won't have access to getting the channel blocks out. To remove that one piece you have to remove two before it.
From Lamont's website... http://lamonstergarage.com/pdf/swaybarRT2014.pdf
Take a look at the end of the doc in Diagram #1. The piece that I am referring to is #308 and #309. You can see in the diagram, part #308 there is a U shaped space near #69 and #82. That is the part that covers the sway bar channel and the blocks in the channel.
any idea of who installs Bajaron swaybar ?
SpyderLovers Sponsor
Any decent mechanic can do the job. It does not require a 'Spyder Tech'.
Finished mine last weekend. I'd rate it at a difficulty of a 4 out of 10.
I also just received the links, which I knew nothing about before I ordered and installed the sway bar. Will simply remove the plastic ones and replace with BajaRon's. Should take no more than 15 minutes once I get her on the ramps.
