Tire pressure Spyder newbie dumb question......
I have a 2014 RT and the manual says 20 for the front and 28 for the back tire. Coming from almost 40 years riding motorcycles, most folks including myself would find a sweet spot higher than what the manual would say. Would love to have real world experience for the 2014 RT tires. They are stock. Thanks in advance.
2014 RT-SE6
Akrapovic Sport Touring 3C Silencer
High Mount Third Brake Light
Kuryakyn Black ISO Motorcycle Grips
LaMonster Spyderdock
LED’s everywhere!
Russell Day-Long w/ Backrest
Seal Floorboards
Spyderpops Bump Skid
Spyderpops KOTT Grill (Keep Out The Trash)
Squared Away Alignment
Riding taught me why dogs stick their heads out the window!
Recommend using the BRP specs on the tires. To soft gives a soft and squirrely ride. More than 28 in the rear will expand the tire and make it wear out prematurely in the center of the tread.
Yep, riding a Harley for the past 20 years, I wasn't buying the specs. Figured it was a typo, but they're on the money.
2015 F3-S. And Another Day To Be My Kids Dad
I have a 2014 RT-S and i run 18 in the front (my preference) 28 in the rear. Most important is that you have both front tires at the same pressure, 1/2 lb off will affect your ride.
find your sweet spot and stay with it.
Cruzr Joe
I run 17.5 in front and 28 in the rear.
21 & 28 for my Bike!
Tough one..!!
considering your ryding style, weight, double or single ryder makes for a wide range of recommondations. Always recommend you start with their suggested pressure and adjust it to suit you. JT's Machine Shop (sponsor on the home page) has a dual filler for the front tires that keeps them equal...good luck..!!
2012 RS sm5
I've been running the nominal tire pressure in accordance with the Owners Manual.
20 psi front & 28 psi rear.
2014 RTL-SE6 Cognac (Current Love)
2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
Jt's Machine shop is a vendor on here and sells a neat little device that you connect to both front tires and fill from a common fitting,making sure you get exactly the same pressure in both front tires.
Digital tire gauge are best help. 19 front 28 rear.
2012 Spyder RT SE5 Brake pedal mod
pressures
This might freak some out been running front at 23psi and rear at 17psi since wife wore first oem tire out at 6000mi. in 2010, have run 215/60-15 every since at 17psi , she has 70,000mi. now averaging approx. 25000 mi. per rear now but she rides solo and pulls camper so she scuffs tires bad, riding two up I don't know how long a tire would last ,I would guess at least 30,000. At 17psi. tire wears evenly no more wore out center, currently running General Altimax Rt front and rear.
I like 25 in the front, was running 18 but didn't like the feel the tires are going to roll off the rim in corners......must be the Baja Ron Sway Bar and Elka shock effect! :-)
I ride 22 in front for local area casual riding and 25 for hard core twistie riding, always 28 in the back...
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
Tire pressure
Here’s a trick my father-in-law told me about. During the war, tires were hard to get and were on ration. To get the most wear out of a set of tires he would mark a line across the tread of each tire from one side to the other with a large piece of white chalk. He would drive in a straight line for about a quarter of a mile and then check the chalk marks on the tires. If there was no chalk visible on the center of the tire he would add air until the chalk line wore off evenly. Sometimes front tires took more air than the rear tires to wear evenly. Don’t forget miss alignment and toe in has an huge effect on wear and stability.
