I have a 2013 RT-S and it does not have a heated seat. So I'm going with they don't come standard on the 2013 RT mine does have heated grips which were standard.
The harness comes with the seat and plugs into a large black connector below the glove box and in front of the gas tank. You also need to connect the rround wire to the ground bolt in back by the rear trunk.You need to take off all the left side tupperware including the black cover by the left passanger hand grip to install.
2021 Sea To Sky, 2020 RTL
Isn't it weird that in AMERICA our flag and our culture offend so many people...... but our benefits don't?
I stock them right here in California.... not much need here but I ship most everywhere.
Heat Demon the best....you install them your self and SAVE SAVE SAVE $$$$
The heater kits are easy to install,
so how much are the heater kits and where do you put the switch?
The 2013 RT comes standard with a heated seat, and it needs no electric connector plug. They discontinued that feature on the 2014 models.
Originally Posted by flamingobabe
GREAT response......took me a second....them ROTFLMAO
i had a 2013 RTS and it definitely had the heated seat. It surely wasn't an option but rather it was standard equipment. I did have the optional after burner but I wouldn't really recommend that option.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
My 2013 RT LTD does not have a heated seat. Wish it did.
No you don't. . With tongue in cheek, I was alluding to the "natural" heat generated by the 2013 RT.
Welcome to the forum. This is a good place to learn a lot about Spyders. As another 2013 RT owner (who really does love this trike), I look forward to your posts. Sorry for the spoof.
Do all 14's have the connector or is that just for the L? I have my corbin heated seat wired to the rear accessory plug right now but if there is a factory connector I'd rather get the proper connector end for it and plug in there.
Eric
YNC(SS) (Retired) - U. S. Navy Submarines
2014 RT-S Cognac
3 seadoo's,CBR250R, Suzi GT750 waterbuffalo's x4, Rebel 250, MB5, '84 Alfa Spider, '97 Jeep TJ, '93 Saab C900CVT, '99 SLK230, '65 Mustang, '59 Fairlane, '48 Ford 8n
I think Corbin should be able to tell you that and also provide detailed installation instructions. Did the seat not come with any printed information?
They all do, but it connects it so the seat heats with the handle grip heaters (Spyder heated seat doesn't have a switch to turn it on and off). You do not want that for the Corbin. The way you have it connected is the best way.
The heater kits vary depending on what you want single or double The double kit comes with front and back heaters and a HI/LO switch with a power port you can mount the switch on the side of the seat or any place<you like. The Heat Demon is the best unit out there on the market. Single kit full price is $ 149.95 and the dual kit $ 199.95 I have them for $125.00 Single and $ 169.95 Dual kit Dave Call me 209-887-3283
[QUOTE=bcoulter19;887729]so how much are the heater kits and where do you put the switch?
