Results 1 to 23 of 23
Thread: Heated seat?
    Very Active Member Buggy's Avatar
    Ontario Canada
    Default Heated seat?
    Is the wiring plug that the optional heated seat plugs into already on the RT or do you have to install it.
    Thanks
    2016 RT Ltd. , Pearl White
    Jun 2014
    California
    I don't know why the RTLT shouldn't have come standard with a heated seat and cb radio
    Sep 2013
    Houston
    Quote Originally Posted by OwnerOfHarriet View Post
    Cost, and there are many owners that have no need of either of those items. Better they stay options.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by Mobey View Post
    Thanks
    The 2013 RT comes standard with a heated seat, and it needs no electric connector plug. They discontinued that feature on the 2014 models.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    I have a 2013 RT-S and it does not have a heated seat. So I'm going with they don't come standard on the 2013 RT mine does have heated grips which were standard.
    ...in the pink (Girls On Spyders) flamingobabe's Avatar
    May 2010
    Friendswood, Texas
    Quote Originally Posted by robmorg View Post
    GREAT response......took me a second....them ROTFLMAO
    #IamARyder #RideASpyder #CanAmSpyder
    Feb 2013
    Pittsburgh, PA
    I agree.
    Soooo... Is the harness already on the bike; or not?
    Mar 2013
    The harness comes with the seat and plugs into a large black connector below the glove box and in front of the gas tank. You also need to connect the rround wire to the ground bolt in back by the rear trunk.You need to take off all the left side tupperware including the black cover by the left passanger hand grip to install.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Linden, CA
    Default If you want a heated seat......
    I stock them right here in California.... not much need here but I ship most everywhere.
    Heat Demon the best....you install them your self and SAVE SAVE SAVE $$$$
    The heater kits are easy to install,
    Quote Originally Posted by PW2013STL View Post
    Aha!
    Thanks for the answer!!
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    so how much are the heater kits and where do you put the switch?
    Jun 2010
    Las Vegas
    Quote Originally Posted by flamingobabe View Post
    i had a 2013 RTS and it definitely had the heated seat. It surely wasn't an option but rather it was standard equipment. I did have the optional after burner but I wouldn't really recommend that option.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Invalid Emails
    Jun 2014
    Edmonton AB Canada
    Default 2013 RS-S has an awesome leg warmer
    For Spring/Early Fall we have a leg warmer!
    But hey, then comes next Summer, it's then once again, leg of lamb BBQ season... ;-)
    Buy a RENS Sheepskin, @ your local IKEA.
    Chas
    Ontario Canada
    Aha!
    Yes I second that!
    Jun 2014
    Flat Rock, Michigan
    My 2013 RT LTD does not have a heated seat. Wish it did.
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by Inspector View Post
    No you don't. . With tongue in cheek, I was alluding to the "natural" heat generated by the 2013 RT.
    Welcome to the forum. This is a good place to learn a lot about Spyders. As another 2013 RT owner (who really does love this trike), I look forward to your posts. Sorry for the spoof.
    Rob
    2013 RT Limited
    Yup...
    And
    May 2014
    United States. North Carolina
    Do all 14's have the connector or is that just for the L? I have my corbin heated seat wired to the rear accessory plug right now but if there is a factory connector I'd rather get the proper connector end for it and plug in there.
    Eric
    YNC(SS) (Retired) - U. S. Navy Submarines
    2014 RT-S Cognac
    3 seadoo's,CBR250R, Suzi GT750 waterbuffalo's x4, Rebel 250, MB5, '84 Alfa Spider, '97 Jeep TJ, '93 Saab C900CVT, '99 SLK230, '65 Mustang, '59 Fairlane, '48 Ford 8n
    Oct 2014
    Deep South
    Quote Originally Posted by Woodsrider View Post
    I think Corbin should be able to tell you that and also provide detailed installation instructions. Did the seat not come with any printed information?
    Mar 2013
    They all do, but it connects it so the seat heats with the handle grip heaters (Spyder heated seat doesn't have a switch to turn it on and off). You do not want that for the Corbin. The way you have it connected is the best way.
    Linden, CA
    The heater kits vary depending on what you want single or double The double kit comes with front and back heaters and a HI/LO switch with a power port you can mount the switch on the side of the seat or any place<you like. The Heat Demon is the best unit out there on the market. Single kit full price is $ 149.95 and the dual kit $ 199.95 I have them for $125.00 Single and $ 169.95 Dual kit Dave Call me 209-887-3283
    [QUOTE=bcoulter19;887729]so how much are the heater kits and where do you put the switch?
