Makes me wonder, what else is not covered on the ...Extended Warranty..
RT-S PE#0060
lots
That seems strange. Is it the B.E.S.T. warranty?
USAF '69-'89 E7
Thailand/Vietnam 1972
Yes bought it when i bought the bike new in 2012
I would be contacting BRP a radiator fan is not a "wear and tear item" or a "maintenance item". In fact it does not mention the water pump either which is a known weak point nor any part of the cooling system. It is not specifically mentioned either way on the website maybe they would reimburse you as a "goodwill gesture"
http://can-am.brp.com/spyder/owners/...roup-429706510
http://can-am.brp.com/content/dam/ca...Protection.pdf
B.E.S.T. EXTENDED SERVICE
Whether you're on the highway or a country road, B.E.S.T. protection lets you focus on your vehicle – and enjoy every minute of the ride.
Best Coverage, Best Parts, Best Value · Extending your warranty: The best coverage for the best vehicles.
B.E.S.T. offers 12-, 24-, or 36-month coverage beyond the manufacturer’s warranty on most BRP vehicles, kicking in the second your vehicle’s limited warranty expires.
· Nationwide service: Coverage that travels with you.
The great outdoors is even greater when you’re riding worry-free! You’re always covered. B.E.S.T. repairs can be done through any authorized BRP dealer in North America.
· Only genuine BRP parts and service: Trust the team that built your vehicle.
The B.E.S.T. protection plan guarantees service from BRP-certified technicians, using only genuine BRP parts, so your vehicle runs as well as the day it rolled off the assembly line.
· Fully transferable, at no cost: The ultimate accessory.
B.E.S.T. transfers ownership whenever your vehicle changes hands, at no cost to either the buyer or seller.
· Unlimited mileage protection: Have fun without watching the clock.
The B.E.S.T. protection plan doesn’t saddle participants with mileage, usage or time restrictions. Our goal is to make sure you can depend on your vehicle and get maximum enjoyment out of it.
COVERED ITEMS
ENGINE
- Pistons
- Cylinder heads
- Cylinders
- Muffler
- Crankshaft
IGNITION & STARTER - Rewind starter
- Starter relay
- Stator
- Magneto
- Electric starter
ELECTRICAL - Ignition switch
- Voltage regulator
- Electronic modules
- Speedometer / Tachometer
- Vehicle stability system
TRANSMISSION/PROPULSION - Drive shaft
- Riding plate
- Transmission
SUSPENSION & DRIVE SYSTEM - Differential
- Drive shaft
- CV joints
- Drive axle
- Countershaft
- Chaincase
FUEL SYSTEM - Fuel tank
- Fuel injector
- Fuel pump
- Carburetor
- Throttle body
BRAKES - Calipers
- Master cylinder
- ABS
- Speed sensors
Note: Accessories, normal wear and maintenance items such as tires, batteries, bulbs, filters and lubricants are not covered
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
I think it's a good idea to have seperate fuse on fan and lights .
2012 Spyder RT SE5 Brake pedal mod
Well, at least the dealer got you in and out and on your way....some upside...no?
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
Let me say this it was on 4th of July how many dealers you know would have got me up & back on the road on a holiday truly the best customer service i have seen in a loooooong time
Rewaco RF-1 GT
10.57 gallons
Really..!!!
Whether you're on the highway or a country road, B.E.S.T. protection lets you focus on your vehicle – and enjoy every minute of the ride .
COVERED ITEMS
ENGINE
- Pistons
- Cylinder heads
- Cylinders
- Muffler
- Crankshaft
- Starter relay
- Stator
- Magneto
- Electric starter
- Voltage regulator
- Riding plate
- Transmission
- Drive shaft
- CV joints
- Drive axle
- Countershaft
- Chaincase
- Fuel injector
- Fuel pump
- Carburetor
- Throttle body
BRAKES - Calipers
- Master cylinder
- ABS
- Speed sensors
This seems to be an automobile policy. We have no cv joints no driveshaft, chaincase cover diferencial etc. No wonder they can pick and choose what they will and will not cover....
2012 RS sm5
