Whoaaa?
Your cruising down the road fat dumb and happy. Well fat anyway. Suddenly you notice the Spyder loosing speed. You crank the throttle, no response. Then you notice something else, no engine sound. Oh s*^t! WTFO? Quick thought, kill switch. Yep, restart good. No crash and burn, no ejection. I was pulling the sleeve down on my right arm, must have hit the kill switch with my left hand.
USAF '69-'89 E7
Thailand/Vietnam 1972
Member: Royal Order of Rat Bastards
SpyderLovers Sponsor
Ditto for 'Been There, Done That'. It can be pretty exciting depending on the situation you're in and how long it takes to figure out what you did.
Fun, fun, fun..!!
happens to many. Can really throw you for a loop...glad it was that simple...!!
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
been there, done that! The wife likes to flip that switch when she gets on. Had some rather embarrassing moments until I remember. Now it's the first thing I check....glad it wasn't serious!
My wife did too
So I changed that switch to the passengers seat ejection
Now she's the "X"
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
Kind of did that this summer, I was pulling up to a toll booth and in preparing to get the change that I had prepared, I let go of the throttle grip and then hit the kill switch as I was grabbing for the handle bar again.
I was confused for a second when the engine died but then realised what I had done.
I managed to flip the switch, hit the brake, press the starter, shift back into gear and hand out the change without holding up traffic behind me.
Done it more than once on more than one type of motorcycle...
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
Yeah. Me too. And every time it I feel like a major idiot. Even though I AM an idiot, I usually don't feel like one.
Dan
2012 Viper Red Rt
upgrades:
Baja Ron's Anti-Sway
Diamond-R Arm Rests
Gloriders
High mount brake light
chrome front fender garnish
Bad Boy Horn
Chrome Deflector Rack
Chrome Scuff Nose Accent
Handlebar Grip Fringe
Gremlin Bells
Did it in my truck going home on the freeway. You know how your not suppose to hang lots of keys with ignition key. It can screw up your ignition switch with all that weight. Well, I never got that memo. Key ring heavy, shut off my truck when I hit a bump doing 65, all the same symptoms...no more power steering, Veroom all gone.
2015 F3-S. And Another Day To Be My Kids Dad
Try accidentally hitting that kill switch at 4am in the middle of the pitch black country roads. Didn't realize what I did for 5 minutes while using my phone for a light to trouble shoot.
At least I put my helmet back on before I Gibbs slapped myself.
Current
2016 Can Am F3T Special Series
2015 Can Am Renegade 1000 X XC
2011 Can Am Outlander 800R X XC
Previous
2012 Can Am RS SE5
When I was working, we used to get calls all the time for machine (rider floor scrubber) quitting. The operators had those key rings that had 20 keys on them. The weight would pull the key switch to off.
USAF '69-'89 E7
I haven't done it while moving . . . but have bumped it a couple times at red lights as I stretch a bit during the delay . . . the first time, it was a major WHAT THE ?? . . . but once I realized what I'd done, that first time, the feeling of being an idiot burned so deeply that, the next time it happened, I don't think anyone else even noticed. I simply stopped running . . . and started again, because I knew, immediately, that I'd been an idiot, again!
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
No need to go through all that. Just flip the switch and crack the throttle. At least that's all I've had to do the some 20 times I've done it going 70 mph in 2400 or so miles on my current trip! And that's with the SE5. Of course I had to reset the cruise control! The kill switch is in the way of my arm when I reach to make adjustments on my GPS which is mounted above the right speaker.
