Belt Tensioner
Anyone have the Smoothspyder Belt Tensioner installed on the RT. Thoughts please!!!
Sent from my SAMSUNG-SM-N900A using Tapatalk
Shooter
__________________
Steve Chamberlain
2017 F3 Limited
Little Elm, Texas
972-467-8077
Smoothspyder review
I bought a Smoothspyder belt tensioner about 3 months ago and it helped a lot. I had a lot of vibration between 70-75mph, which is a pretty common highway speed here. I installed the Smoothspyder it definitely eliminated the vibration. A couple of caveats though. It was not easy to install because of the drilling required and the tensioner started loosing up after about 600 miles causing the vibration to return. I've since reset the tension and it hasn't given me any more issues in 1100 miles. I hope this helps.
I'm pretty sure that the 2014 RT DOESN'T require any holes to be drilled...It uses a existing single hole with a supplied bolt and nut from Jim???
I talked with Jim at Smooth Spyder about a week ago...I'm going to order one after my 3000 miles service this Tues. (9/30)...So sometime in the next two weeks I'll know for sure...
I installed a Smooth Spyder belt tensioner on my 2014 RTL about 2 months ago
you do not need to drill any holes
It has stopped the vibration on mine
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
My dealer installed one for me on my 2013 RT L & it has made a huge difference in calming the vibration. I would recommend that you go for it. I'm glad that I did.
I have a 2012 rt-s sm5. I put the smoothspyder tensioner on, about a year ago. Around 65 to 75 going up hill it will make a noise. Do you think it could be to loose or to tight didn't want to put to much pressure the bearings. Have it set about half the scale that Jim marked on it.
Thanks as always
This has been informative. Thanks. I'll have to get one on order.
Shooter
__________________
Steve Chamberlain
2017 F3 Limited
Little Elm, Texas
972-467-8077
SpyderLovers Sponsor
Thanks as always
PM sent. Anyone that has questions or issues of any kind can call me, I'm here for that.
Thanks Jim
Shooter
__________________
Steve Chamberlain
2017 F3 Limited
Little Elm, Texas
972-467-8077
Smooth Spyder
What's the price for the new unit for a 2013 RT Limited?
Go to SpyderLover"s "HOME", and click on th link to SmoothSpyder"s website link...
2014 RT SE6 Rider
X - Honda Rider
X - RT S driver
X - RS driver
Lifetime VFW Member
I have installed my smoothspyder tensioner on my 2014 RT. a month ago it is working ready good no properly smooth is the word!
