Results 1 to 5 of 5
    Jax Beach, Fl.
    Default Oil Sump Capacity
    Anyone know the oil sump capacity for the ACE 1330 3-cyl SE6 as showen in the shop manual?
    2014 RTL-SE6 Cognac (Current Love)
    2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by A1A View Post
    http://www.spyderlovers.com/forums/s...il-recommended
    Post 13 by Lamont.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default 2nd Oil Change at 10,000 miles
    Completed 2nd oil change with filter recently. I used the "recommended oil quantity" per Lamont's chart (http://www.spyderlovers.com/forums/s...il-recommended Post 13) below:
    Less oil recommended per chart below:
    4.7L = 5 quarts and that's what I put into the engine. Just got back from a 30 mile run and checked oil level.
    FYI - oil level on dipstick: It is showing at the "low" mark on the dipstick.
    Since the 2014 RT has been AWESOME and has not used a drop of oil, I will monitor this level and insure it does not go below that mark. IF this is the new recommended oil level, then why do we use "old" measuring dipsticks. It would seem a new dipstick by BRP is in order here to insure we follow proper oil levels in our engines on the 1330's. IMHO !
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Jax Beach, Fl.
    Thanks for the response folks! My bad, I meant to say. what is the Oil Tank Capacity in accordance with the shop manuel?
    Very Active Member den1953's Avatar
    Sep 2013
    Fostoria, Ohio
    Default Thanks
    Useful information is always appreciated. I just wish they would go to a more modern spin-on oil filter. Anything that simplifies doing oil changes is also appreciated.
