Results 1 to 21 of 21
    Jun 2014
    Strongsville
    Default To Oil Change or Not To Oil Change
    Hi Everyone,
    Hope that it's been a good riding year for all. I will be storing my 2010 RT-S in about a month. I'm just about at 5000 miles since my last oil change (which is normally how long I go). I'm looking for some feedback on storing the trike. Should I:
    1. Change the oil now, ride for a month, store for winter
    2. Keep riding, change the oil just before storing
    3. Keep riding, store for winter, change the oil next year when I break it out in spring
    As always, thanks in advance.
    Michael
    You call it a midlife crisis. I call it all the things I wanted to do!
    2010 RT-S SE5
    SoFlo
    Quote Originally Posted by mpapatonis View Post
    Hi Everyone,
    #3 absolutely not in my book. Get the condensation and acids out before storing.
    #1 & #2, use the 10% rule. If your riding before storage is less than 10% , 500 miles, ride it, oil change, then store. More than 10%, change just the oil and refer to #3.
    My thoughts, but see how others see it.
    PK
    Aug 2013
    Anderson, South Carolina
    Default Change it now
    My vote would be for option #1
    Why would you want to drive around with oil that most likely has lost some of the viscosity and is also contaminated from normal use? It will just cause premature wear.
    Jun 2014
    Strongsville
    If I change the oil now or just before storing, do I need to change it again in the spring or will it be ok, since I'm not running the trike during storage?
    Michael
    2010 RT-S SE5
    Changing it at the end of the Season, and again at the start of next Season... innecessary!
    One; or the other; not both. I'd change at the beginning of the Season, and It'll be ready for some serious riding!
    Active Member Raknid's Avatar
    Central NJ
    If not riding more than 500 to 1000 miles before storage, I would ride it, change the oil, and then store it. Probably no big deal if you change it now, ride 500 miles and store it ( no need to change again in the spring). What you want to avoid is storing with dirty, contaminated oil.
    Aug 2007
    Greeneville, TN
    #1 and you'll be fine in the spring.
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Change before storage. Especially with 5K on the old oil. Contaminants in the old oil will settle out to the bottom of the crankcase. They can be pretty corrosive.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Jun 2011
    Near Lexington, NC
    You're running on very thin oil now; be assured the viscosity has sheared down to 20W or less. I'd siphon a quart out and top off with fresh oil, then do the full oil and filters change when you store it. You might have a warm fall and ride longer than you expect.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Greenville Tx
    PK
    WHAT DID I JUST READ!
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    With Bob! I asked this same question when I first bought the Spyder and a very smart man, with lots of MC experience,who is no longer posting (NancysToys)said the samething! Especially with the new oils these days, I do this with all my summer vehicles and never had an issue. Changing right before storage and then before riding in the spring, in my opinion is both unnecessary and expensive!But to each their own!
    2012 RT , stock Lava Bronze
    Oct 2013
    rome new york
    Quote Originally Posted by Netminder View Post
    With Bob! I asked this same question when I first bought the Spyder and a very smart man, with lots of MC experience,who is no longer posting (doc)said the samething! Especially with the new oils these days, I do this with all my summer vehicles and never had an issue. Changing right before storage and then before riding in the spring, in my opinion is both unnecessary and expensive!But to each their own!
    AGREE!!!!!!
    Don't follow me; I'm lost too!
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Not that I do not value your input Bob, I do! But we all know the experience that NancysToys has, so his advice is like gold!My bad, but I meant NancysToys, which I am sure you figured by now!
    I'd follow Scotty anywhere he chose to lead me.
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Once again, I miss his solid advice and knowledge!
    Oct 2013
    rome new york
    Technology is great
    Out with the old in with the new
    Default Depends..!
    how much you ryde a month. Agree with Ron change it now you will be tapering down anyway...
    ​2012 RS sm5
    Very Active Member Dan_Ashley's Avatar
    May 2013
    Redlands, Ca
    If it is time to chage it, then do so. Don't put it off because then you will forget.
    Dan
    2012 Viper Red Rt
    upgrades:
    Baja Ron's Anti-Sway
    Diamond-R Arm Rests
    Gloriders
    High mount brake light
    chrome front fender garnish
    Bad Boy Horn
    Chrome Deflector Rack
    Chrome Scuff Nose Accent
    Handlebar Grip Fringe
    Gremlin Bells
    SoFlo
    Quote Originally Posted by AY4B View Post
    In easy to follow simple terms...The original post had a choice of three numbered items. 1, 2, and 3.
    From the original post.
    My reply was, based on the original post 3 items. In my experience and opinion.
    Used oil holds moisture and acids, not good for an inactive engine or gearbox. Storing in this condition is not best.
    If the original post person opts to continue riding, an amount of 10% more than his 5000 change interval will be easily handled. So a change of oil and filter at 5500 should be a non issue. In theory, he could ride this fall, not exceed approx 5500 on the oil and change before storage. Cost effective and best for the engine and gearbox.
    If the op, plans to ride a lot in the fall months, then he should change the oil and filter now. Then repeat the oil and filter change for storage in my opinion.
    Can the OP store it with low mile oil and filter, certainly, it is his machine. Is it best, no. If this were my machine, and stored with used oil, I would without doubt, run the engine several times during storage to prevent or minimize chances of pitted bearings, cam concerns, and ring marks on the cylinders.
    If the op does his own work, the cost is minimal for best results. Overal though, however each person decides is their own choice.
    Consider also, unless the engine has one cylinder, at least one other cylinder has the valves or a valve open to the ambient conditions.
    PK
    Aug 2013
    Northern California
    Default What
    ...is this "season" that you speak of? You mean you don't ryde all year long? I hope everyone on this board can extend their season as long as possible......and to be honest with you I am hoping that we can't ryde as much as last year (we missed one weekend last winter) we need rain damn it
