Results 1 to 15 of 15
    Jun 2013
    queens ny
    Default inspection stickers
    for people that live in states that require inspections on their bikes, where does the dealer or inspection station place your sticker. my dealer put's it on the top left A arm and so far i have lost two of them. i watched them clean off the area b4 putting it on but i still keep loosing them.
    it is either a bad batch of stickers or i am just going way too fast
    NO BIKE AT THIS TIME
    Invalid Emails
    Jun 2014
    Edmonton AB Canada
    Default Slow down you move too fast...
    You got to make them stickers last... ;-)
    In my life, Everything relates to song.
    Chas
    I normally put mine on the left lower A-arm; I don't know if that should make a difference or not.
    This could be a case of surface preparation being a bit careless...
    I think that there are "adhesion promoters", that help make surfaces stickier...
    The sticker on my 2014 got slapped on the swingarm out back, and it's staying put just fine!
    But slow down anyway!!
    Maybe wrap the sticker with some of that clear packing tape that comes on a roll like duct tape. That stuff is a "bear" to get off when you put it where you don't want it.
    Active Member srwilli's Avatar
    Sep 2012
    Beverly Hills, FL
    Texas puts the sticker in the rear below the license plate.. Now that I am in FL no inspection...
    2012 RT Limited
    SpiderWrap Graphics
    KewlMetal DualKewl FenderZ Running Lights
    TricLED Dual Running & Brake Lights
    Seal Floorboards
    Bajaron Anti-Sway Bar
    Utopia Backrest
    Diamond R Luggage Rack
    SpyderPops Upper Blockoff
    SpyderPops Catalytic Converter Shield
    wv
    Doesn't have to be on show in WV... Got it under the seat on my STs.
    Default Let's see..!!
    back when I worked in Texas they had an extension on the license plate backer. Seeing as most put them anywhere why not make a wing off somewhere special for it.
    ​2012 RS sm5
    Very Active Member Eagle1's Avatar
    Nov 2013
    Lutz, fl
    Use a couple of clear wire ties to keep it in place.
    Ryde as if your life depends on it,
    because it does !! Ryde Safe!
    Vietnam 67-69
    John,
    Have them wrap the stick around the leading edge of the A-arm cover. That way, the sticker's leading edge won't be in a position of being peeled-back by the air flowing over it.
    Jun 2011
    Winchester, VA
    My inspection sticker's on the bottom of the passenger footpeg.
    Oct 2013
    rome new york
    Mine is on the front left shock
    Oct 2013
    rome new york
    Quote Originally Posted by cuznjohn View Post
    Clear gorilla tape on the edges
    Sep 2013
    Houston
    Quote Originally Posted by srwilli View Post
    Texas inspection stickers are going away in Feb.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Bossier LoUiSiAna
    Every state seems to be different,my state LA,crooked pain in ass, but as with most bikes we keep with paperwork,only on base do they need to see 24/7 , g'luck. If the inspector dont know laws for it, not good signż!
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    Front left shock.
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
