Some 2014 torque values pleae
Have a 2014 RT, looking for torque values for rear hub to wheel, and brake rotor disc to hub.
Mounted a new Yokahama S-Drive rear tire, ready to put back together.
Thanks,
DubuqueSpyderRyder
I torqued the wheel at 150 ft. lbs. Just really snugged up the caliper bolts. Probably 25-30 ft lbs. would be plenty. Use a drop of loc-tite. on the caliper bolts. Hope that helped.
You probably already got the info but if not, the rear wheel torque value is in the owners manual.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Rear drive axle nut torque 210 N•m to 240 N•m (155 lbf•ft to 177 lbf•ft) Page 164 in the manual....
Thanks
Thanks Doc, Ann, and bgame for your replies. Much appreciated.
DubuqueSpyderRyder
