Results 1 to 16 of 16
Thread: Heated grips
    Registered Users Mike X's Avatar
    Jan 2013
    Beverley E.Yorkshire UK
    Default Heated grips
    Fitted a set of Oxford heated grips to my RSS , ready for the cooler evening air .image.jpg
    Jan 2013
    Another pic of my heated grip set up .
    Oct 2013
    rome new york
    Was it an easy install?
    Jan 2013
    Default Spyderpops bump skid RSS
    Thought I would show you guys my recently installed Spyderpops bump skid .
    wv
    Looks great!
    Wish there were the same amount of farkles for the newer ST!
    Jan 2013
    Yes , very , had them sitting in the garage for ages too before I plucked up the courage to fit them .
    This system just needs 2 wires running to the battery , the rest is plug and play
    Jan 2013
    I guess they will come Zamfield , no doubt people are beavering away , designing new farkles as we speak .
    Invalid Emails
    Jun 2014
    Edmonton AB Canada
    Default Heated grips would have been nice while ryding today...
    It was still a wonderful day to be out ryding the Spyder. I was surprised just how many other bikes were out on the streets today. Even though the chill was in the air. The bright Sun did make an appearance or two, but never for any great length of time. Not enough to make much of a difference, temperature wise.
    Still got a lot of pleasant waves, hoots, and the regular friendly comments at the red lights.
    Spyder ryding, it makes me feel like a minor celebrity. ;-)
    Chas
    Registered Users Spyder ri's Avatar
    Warwick, RI
    I have the same heated grips on my RS. I love them.
    Mar 2012
    NJ
    I used Polly heaters. http://www.pollyheaters.com clean install with no visible wires. Also allows you to run whatever grips you want and swap grips when they get worn.
    Active Member Craniac's Avatar
    Feb 2014
    Roswell NM
    Polly heaters will not work on an ST. I tried.
    Mar 2012
    NJ
    Quote Originally Posted by Craniac View Post
    What's inside the bars preventing them from going in?
    Feb 2014
    Roswell NM
    Quote Originally Posted by DrewNJ View Post
    Bars are solid. The portion of the bars under the grips is made of solid metal. Hence, the polly heaters will not go in.
    Mar 2012
    NJ
    That sucks...
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    heated grips rapidly become a necessity rather than a luxury once you use them a bit. Glad to see you get them
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Oct 2015
    Germany
    Arrow
    And from the inner side? Is there a way?
