Page 1 of 2 12 LastLast
Results 1 to 25 of 47
    Nov 2011
    Gillespie, Illinois
    Default Replacement tire forf 165/55R15
    Has anyone replaced the original 165/55R15 Kenda front tires on their 2014 RT with another tire and size? A car tire will work, if I could find the right size. Thank you.
    2015 RT LTD , Red
    Federal has one...
    Mar 2008
    Hesston, PA
    Quote Originally Posted by gl1800 View Post
    I just ordered a set of Federal EVO 595 165/55R15 today...
    I made this decision after talking (PM) to several SL members that are using them...
    Mine won't be installed until I get my front wheels painted to match this winter...
    I purchased mine from; http://www.performanceplustire.com/p...65_SLASH_55-15
    Active Member sledmaster's Avatar
    Sep 2007
    Minnesota
    The Federal EVO 595 is a "drifter" tire with very stiff sidewalls. Not really a good tire design or construction match for a Spyder. The only good thing about it is the exact 165/55-15 size match. I would be very careful using the Federal in the rain.
    Your better options IMO would be the Kumho Solus KH16 in the 175/55-15 size or 155/60-15 size. The 175 is 10mm wider and only +2.0% larger diameter, where the 155 is 10mm narrower and only +0.9 larger diameter. Has AA traction and A temperature rating. Should be a far better match in terms of tire construction, traction and tread design for wet conditions.
    2021 RT Limited - Deep Marsala Red – 4,200 miles
    2013 ST-S SE-5 - Circuit Yellow – 56,000 miles
    2015 F3-S SM-6
    - Can-Am Red Solid Gloss – 2,000 miles - SOLD
    2008 GS SM-5 Premier Edition #659
    - Full Moon – 34,000 miles - SOLD
    2008 GS SM-5 Premier Edition #006
    - Full Moon – 34,800 miles - SOLD
    There are a couple of 155/65-15s available that would be MORE than close enough to the OEM sizing.
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    I was out looking to replace the Kenda tires though they have only 3200 miles. I just want something with better performance in those nightmare turns. I went to Bridgestone dealers and they have no performance tires thoush they do have a Drive Guard which I don't know about. Federal dealers said they have NO tire in the 155/55R15 size. I did find one web site that reported they had that size in the Federal tires $69. I don't think you can buy a decent performance tire for that price. I talked to the Michelin dealers, no tire that size. Three strikes out today.
    I saw a post of stating that a Kumho in 175/55 was available. I also read a post someone said that a 185/55 would'nt fit the wheel cover. The 175 is 10mm wider. Anybody with real world experience with this size tire?
    My goal is better performance in the curvy parts of the road. I have Bajaron Swaybar, and will soon have Elka 1+ shocks. Tires is all that's left of that performance combo.
    It is said the RT won't turn over, but I'm not convinced just yet. Or that yellow streak makes too bright a light for some folks...
    Aug 2013
    Quebec City, Quebec
    Continental ContiProContact 155-60/R15.
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    I've been running Bridgestone Potenzas in that size for about 5,000 miles now with no problems. Both fronts cost the same as ONE OEM tire.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Jun 2015
    Calhoun, La
    Quote Originally Posted by Double Trouble View Post
    I went to the Bridgestone tire dealer today and he threw me out the door when I insisted there was a Potenza tire size 165/55R15. OK maybe not but they WERE insistent that it does not exist. I'm confused. That would be my preferred tire. After Michelin. Which also does not make that size tire.
    Where is your tire dealer? I'd like to ask him.
    Mar 2013
    South East Wisconsin
    Default About 3,000 miles ago I installed
    a set of Federal EVO 595 165/55R15 front tires prior to a trip.
    We rode two up and fully loaded. The Spyder only had 8800 miles on it at the time and although laser aligned and pressure kept equal at 19 the Kendas were cupping terribly and had weights a quarter the way around the rim. I argued with the dealer they were defective to no avail, so I opted for the Federals.
    We rode on a variety of roads and pavement types, in heavy and light rain as well as varying temps.
    I dislike the Federals immensely for our Spyder RT...
    The Spyder now wanders on grooved concrete, tar strips, and on painted lines like never before.
    Rain performance was ok at best.
    Hard cornering feels near the same.
    I with a digital gauge varied pressure from 15 to 17 to 19 to 21 and 23 during the trip and noticed little difference.
    My wife whom has ridden 20,000 + on the back of a Spyder asked me on several occasions what was wrong as she felt like we were geting jerked back and forth.
    I will be going back to Kendas on the front soon, and hope they dont cup like hell again and need weights that encompass a quarter of the inside wheel to balance.
    On a side note, at 29 psi the new S Drive on the rear is wonderful, just hope it lasts longer than the rear Kenda did.
    I know some love the Federals, but this has been our experience...
    Lets ride!!!!
    Idaho
    Quote Originally Posted by ricford View Post
    Better performance in what respect? In my experience the Kendas hold the road all the way to the point where Nanny kicks in so I don't see where a different tire will make a difference. In fact, if you go with a harder tire you're more likely to start sliding the tires in a corner in which case Nanny will kick in instantly. At least that's the way I see it.
    2014 Copper RTS
    Feb 2011
    Loganville, ga
    My error. My '12 has 14" tires. Sorry.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by 1VENOM View Post
    Your best buy for replacement tires, at a low cost would be something like this designed for the spyder. http://www.motorcycle-superstore.com...FUlqfgodqtUHHg
    Vee rubber does not make a front tire for 2013 or later models. That is the size talked about in this thread.
    2018 F3 LIMITED
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2011
    Near Lexington, NC
    Here is a new all season tire that recently hit the market. It can be had for $98 + shipping. Anybody got the nerve to try it?
    http://www.kumhotire.ca/fr/about/company_news/207
    Kumho also make a Solus that has a nice tread. Priced them today at Walmart who said they could order for $89 which includes mounting and balancing. Not sure I'd want them to balance but otherwise their price is very competitive, or better, than Tire Rack.
    I'd sure like to know for a fact that a 175-55-15 would fit under the fenders of the '14 RT SE...the ones with the ridge. I've been told they fit the smooth fenders so I'm guessing they would, but not willing to shuck out over $200 and find they don't.........
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    Quote Originally Posted by sledmaster View Post
    My Federal Evo 595s on the front of my RT have 28000 miles on them already - handle great and show very little sign of wear - I have ridden in rain and storms that most people would not consider - so I have to take issue with your assessment unless you have really ridden the tire like I have....
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by ulflyer View Post
    According to the story that new Kumho is for the Canadian market.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    A little more info please, since Potenza comes in about 15 different models
    TIA
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Jun 2011
    Near Lexington, NC
    I guess I read it that it was developed initially for the Canadian market but this company will ship anywhere. Two to my neck of the woods would be about $225 US. However, what do you think about them? Might they be good on the Can Am? Would love to hear from some of our Canadian friends.
    https://1010tires.com/Tires/Kumho/Solus+HA31
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Oct 2013
    rome new york
    I believe they are making front tires now. Go to Rolo sight
    Default FEDERAL EVO TIRE
    Quote Originally Posted by BikerDoc View Post
    Dear Sir : IMHO " Sledmaster " has probably forgotten more about Spyders than you will ever hope to know......and if you have NOT read Post # 10 above I suggest you do............The people who are into " DRIFTING " are picking this tire for a reason, and I don't think it's for TRACTION......Mike
    Sep 2014
    USA
    Quote Originally Posted by bmccaffrey View Post
    should be out in August 1st I heard..V35003 part number
    Jun 2011
    Near Lexington, NC
    They have that size listed on UK tire sites, but not on U.S. sites!!!
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Jul 2011
    Good to know they just started making them available. Another option.
    2018 F3 LIMITED
    Jun 2011
    Near Lexington, NC
    Does anyone know what the specs are for this tire?
    Its almost too cheap.
    They tell you nothing on the site, just that its made for the Can Am.
    Where is it made? What is the wear rating? What is the composition...nylon belts, steel belts, what?
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
